ASUS P5K Deluxe WiFi-AP (Intel P35)
nella scatola troviamo :
la scheda :
è presente solo un attacco PS2 per la tastiera :
ecco lo schema del chipset P35 + ICH9 :
CPU
LGA775 socket for Intel® Core™2 Quad / Core™2 Extreme / Core™2 Duo / Pentium® Extreme / Pentium® D / *Pentium® 4 Processors
Compatible with Intel® 05B/05A/06 processors
Support Intel® next generation 45nm multi-core CPU
*This motherboard supports FSB 1333/1066/800
Chipset
Intel® P35 / ICH9R with Intel® Fast Memory Access Technology
Front Side Bus 1333 / 1066 / 800 MHz
Memoria
4 x DIMM, max. 8GB, DDR2 1066*/800 / 667 MHz, non-ECC, un-buffered memory
Dual channel memory architecture
* The chipset officially supports the memory frequency up to DDR2 800MHz. Tuned by ASUS Super Memspeed Technology, this motherboard natively supports up to DDR2 1066MHz
Slot di Espansione
2 x PCI-E x16 (blue @ x16 mode, black @ x4 or x1 mode) supports CrossFire Technology
2 x PCI-E x1
3 x PCI
Storage Southbridge
- 6 x SATA 3.0 Gb/s ports
- Supports RAID 0 and 1
JMicron® JMB363 PATA and SATA controller
- 1 x UltraDMA 133/100/66 for up to 2 PATA devices
- 2 x External SATA 3.0 Gb/s port (SATA On-the-Go)
- Supports SATA RAID 0,1 and JBOD
LAN
Dual Gigabit LAN controllers, featuring AI NET2
Marvell88E8056® PCI-E Gigabit LAN controllers
RealtekRTL8110SC® PCI Gigabit LAN controller
Wireless LAN
ASUS WiFi-AP Solo
54 Mbps IEEE 802.11g and backwards compatible with 11 Mbps IEEE 802.11b
- Software Access Point mode
- Station mode : Infrastruceure mode and Ad-Hoc mode
Audio
ADI® AD1988B 8-channel High Definition Audio CODEC
- Coaxial / Optical S/PDIF out ports at back I/O
- ASUS Noise Filter
IEEE 1394
Agere® FW322 1394a controller supports 2 x IEEE 1394a ports (one at midboard; one at back panel)
USB
10 x USB 2.0 ports (4 ports at mid-board, 6ports at back panel)
ASUS AI Lifestyle
ASUS Quiet Thermal Solution:
- ASUS AI Gear2
- ASUS AI Nap
- ASUS 8-Phase Power Design
- ASUS Fanless Design: Heat-pipe solution
- ASUS Fanless Design: Stack Cool 2
- ASUS Q-Fan 2
ASUS Crystal Sound:
- ASUS Noise Filter
ASUS EZ DIY:
- ASUS Q-Connector
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS AI Slot Detector
ASUS WiFi@Home:
- ASUS WiFi-AP Solo
Other Features
ASUS MyLogo 3
Multi-language BIOS
Caratteristiche di Overclock Intelligent overclocking tools:
- AI NOS™ (Non-delay Overclocking System)
- ASUS AI Booster utility
Precision Tweaker:
- vCore: Adjustable CPU voltage at 0.0125V increment
- vDIMM: 16-step DRAM voltage control
- vChipset: 4-step Chipset voltage control
SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 800MHz at 1MHz increment
- Memory tuning from 667MHz up to 1333MHz for DDR2
- PCI Express frequency tuning from 100MHz up to150MHz at 1MHz increment
Overclocking Protection:
- ASUS C.P.R.(CPU Parameter Recall)
Porte I/O Pannello Posteriore
1 x PS/2 Keyboard
1 x S/PDIF Out (Coaxial + Optical)
2 x External SATA
1 x IEEE1394a
2 x RJ45 port
6 x USB 2.0/1.1
1 x WiFi-AP Solo antenna jack
8-channel Audio I/O
Connettori I/O Interni
2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
1 x COM connector
6 x SATA connectors
1 x CPU Fan connector
4 x Chassis Fan connector
1 x Power Fan connector
1 x IEEE1394a connector
Front panel audio connector
1 x S/PDIF Out Header
Chassis Intrusion connector
CD audio in
24-pin ATX Power connector
2 x 4-pin ATX 12V Power connector
System Panel(Q-Connector)
BIOS
16 Mb Flash ROM, AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3
Gestibilità
WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Accessori
UltraDMA 133/100/66 cable
FDD cable
4 x Serial ATA cables
1 x 2-port Serial ATA power cable
I/O Shield
User's manual
ASUS WiFi-AP Solo manual
3 in 1 Q-connector
1 x 2-port USB2.0 / 1-port IEEE1394 module
ASUS WiFi-AP Solo omni-directional antenna
CD di Supporto Drivers
ASUS PC Probe II
ASUS Update
ASUS AI Suite
ASUS WiFi-AP Solo Wizard
Anti-virus software (OEM version)
Image-Editing Suite
Dimensioni
ATX Form Factor, 12"x 9.6" (30.5cm x 24.4cm)
x clokkare sotto windows :
Set FSB Version 2.0.b.15f(beta) ----> configurare : ICS9LPRS916BGLF
link download : http://www13.plala.or.jp/setfsb/
MemSet 3.3 beta 2 per le ram
( beta2 version with Performance Level: memset33beta2
Impressive influence on P35 performance )
link download : http://rv.page.cegetel.net.perso.ceg...Set33beta2.exe
( su segnalazione di pippo369)
NON USARE CORETEMP VERSIONE 0.95 ... E' INCOMPATIBILE ... SI RIAVVIA IL SISTEMA ....
USARE LA VERSIONE 0.94 ---> link download : http://www.thecoolest.zerobrains.com...oreTemp094.zip
x testare stabilità usare Wprime 1.43 : http://www.wprime.net/wPrime_gui143.zip
Vcore :
VMch :
Vdimm :
Ogni Vmod invalida la garanzia della scheda !!!!!
