Opensuse 12.2 : some changes :-)
    pebibyte
    Jun 2005
    Predefinito Opensuse 12.2 : some changes :-)
    Qualche miglioria riguardo le applicazioni ma anche promessa di migliorata gestione del file-manager grazie ad un nuovo kernel....
    Portal:12.2/Features - openSUSE
    Nome:   small.png
Visite:  550
Grandezza:  9.4 KB
    Qui per il download: software.opensuse.org: Download openSUSE 12.2
    pebibyte
    Jun 2005
    Predefinito Unable to install vmnet
    Il nuovo kernel porta con se diverse migliorie ma per un po' di tempo bisognera' tirarsi dietro anche qualche magagna.
    Nell'upgrade dei moduli di vmware compare un errore del genere che pianta la loro costruzione:
    server:/home/server # vmware-modconfig --console --install-all
    Stopping VMware services:
    VMware Authentication Daemon done
    VM communication interface socket family done
    Virtual machine communication interface done
    Virtual machine monitor done
    Blocking file system done
    Using 2.6.x kernel build system.
    make: Entering directory `/tmp/vmware-root/modules/vmmon-only'
    make -C /lib/modules/3.4.11-2.16-desktop/build/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. \
    MODULEBUILDDIR= modules
    make[1]: Entering directory `/usr/src/linux-3.4.11-2.16-obj/x86_64/desktop'
    CC [M] /tmp/vmware-root/modules/vmmon-only/linux/driver.o
    CC [M] /tmp/vmware-root/modules/vmmon-only/linux/driverLog.o
    CC [M] /tmp/vmware-root/modules/vmmon-only/linux/hostif.o
    CC [M] /tmp/vmware-root/modules/vmmon-only/common/apic.o
    CC [M] /tmp/vmware-root/modules/vmmon-only/common/memtrack.o
    CC [M] /tmp/vmware-root/modules/vmmon-only/common/hashFunc.o
    CC [M] /tmp/vmware-root/modules/vmmon-only/common/vmx86.o
    CC [M] /tmp/vmware-root/modules/vmmon-only/common/cpuid.o
    CC [M] /tmp/vmware-root/modules/vmmon-only/common/task.o
    CC [M] /tmp/vmware-root/modules/vmmon-only/common/comport.o
    CC [M] /tmp/vmware-root/modules/vmmon-only/common/phystrack.o
    CC [M] /tmp/vmware-root/modules/vmmon-only/vmcore/moduleloop.o
    LD [M] /tmp/vmware-root/modules/vmmon-only/vmmon.o
    Building modules, stage 2.
    MODPOST 1 modules
    CC /tmp/vmware-root/modules/vmmon-only/vmmon.mod.o
    LD [M] /tmp/vmware-root/modules/vmmon-only/vmmon.ko
    make[1]: Leaving directory `/usr/src/linux-3.4.11-2.16-obj/x86_64/desktop'
    make -C $PWD SRCROOT=$PWD/. \
    MODULEBUILDDIR= postbuild
    make[1]: Entering directory `/tmp/vmware-root/modules/vmmon-only'
    make[1]: `postbuild' is up to date.
    make[1]: Leaving directory `/tmp/vmware-root/modules/vmmon-only'
    cp -f vmmon.ko ./../vmmon.o
    make: Leaving directory `/tmp/vmware-root/modules/vmmon-only'
    Built vmmon module
    make: Entering directory `/tmp/vmware-root/modules/vmnet-only'
    CC [M] /tmp/vmware-root/modules/vmnet-only/hub.o
    CC [M] /tmp/vmware-root/modules/vmnet-only/userif.o
    CC [M] /tmp/vmware-root/modules/vmnet-only/driver.o
    CC [M] /tmp/vmware-root/modules/vmnet-only/bridge.o
    CC [M] /tmp/vmware-root/modules/vmnet-only/filter.o
    CC [M] /tmp/vmware-root/modules/vmnet-only/procfs.o
    CC [M] /tmp/vmware-root/modules/vmnet-only/netif.o
    CC [M] /tmp/vmware-root/modules/vmnet-only/smac_compat.o
    CC [M] /tmp/vmware-root/modules/vmnet-only/smac.o
    CC [M] /tmp/vmware-root/modules/vmnet-only/vnetEvent.o
    CC [M] /tmp/vmware-root/modules/vmnet-only/vnetUserListener.o
    /tmp/vmware-root/modules/vmnet-only/netif.c: In function ‘VNetNetIfSetup’:
    /tmp/vmware-root/modules/vmnet-only/netif.c:134:7: error: unknown field ‘ndo_set_multicast_list’ specified in initializer
    /tmp/vmware-root/modules/vmnet-only/netif.c:134:7: warning: initialization from incompatible pointer type [enabled by default]
    /tmp/vmware-root/modules/vmnet-only/netif.c:134:7: warning: (near initialization for ‘vnetNetifOps.ndo_validate_addr’) [enabled by default]
    make[4]: *** [/tmp/vmware-root/modules/vmnet-only/netif.o] Error 1
    make[4]: *** Waiting for unfinished jobs....
    /tmp/vmware-root/modules/vmnet-only/filter.c:60:16: error: ‘THIS_MODULE’ undeclared here (not in a function)
    /tmp/vmware-root/modules/vmnet-only/userif.c: In function ‘VNetCsumCopyDatagram’:
    /tmp/vmware-root/modules/vmnet-only/userif.c:520:3: error: incompatible type for argument 1 of ‘kmap’
    In file included from /tmp/vmware-root/modules/vmnet-only/userif.c:26:0:
    /usr/src/linux-3.4.11-2.16/include/linux/highmem.h:49:21: note: expected ‘struct page *’ but argument is of type ‘const struct <anonymous>’
    /tmp/vmware-root/modules/vmnet-only/userif.c:523:3: error: incompatible type for argument 1 of ‘kunmap’
    /usr/src/linux-3.4.11-2.16/include/linux/highmem.h:55:20: note: expected ‘struct page *’ but argument is of type ‘const struct <anonymous>’
    make[4]: *** [/tmp/vmware-root/modules/vmnet-only/filter.o] Error 1
    make[4]: *** [/tmp/vmware-root/modules/vmnet-only/userif.o] Error 1
    make[3]: *** [_module_/tmp/vmware-root/modules/vmnet-only] Error 2
    make[2]: *** [sub-make] Error 2
    make[1]: *** [all] Error 2
    make: *** [vmnet.ko] Error 2
    make: Leaving directory `/tmp/vmware-root/modules/vmnet-only'
    La soluzione..basta copiaincollare nella console con i permessi di root (se seguite il sito non mettere i ";" alla fine delle righe )
    Patches for VMware® Workstation 8.0.4 build-744019
    Install:
    # cd /usr/lib/vmware/modules
    # wget http://pavlinux.ru/vmware/8.0.4/source.tar.lzma
    # md5sum source.tar.lzma
    l'output deve essere questo: e37e41a818a47ec868bdb493197aaf63 source.tar.lzma
    # tar -xf source.tar.lzma
    Ultima modifica di giostark : 05-11-2012 a 03:11
    Anche io sono dovuto impazzire un pò con il kernel 3.4 con il vmware player, se non ricordo male...
    Ora ho installato il Player v. 9.00 che dovrebbe supportare nativamente i kernel 3.5 e 3.6... Peccato che su Arch dureranno poco!
    pebibyte
    Jun 2005
    Io ho dovuto rimettere la 8 poiche' una copia di una macchina virtuale, configurata e con molti programmi installati, era stata fatta con la 8. Installo la 9 e mi salta fuori il popup "impossibile importare la macchina virtuale poiche' fatta con una versione precedente" ( o qualcosa di molto simile ). Di win 8 non mi interessa..al massimo aggiorno i tool se ci sono migliorie per la grafica e co.
    Boh.. Strano.
    Hai provato magari ad esportare la vm in un'applicance e reimportarla? A me le VM create sotto linux con la 8 sono partite senza problemi sulla 9 sotto Windows.
