MSI Nforce4[MSI K8N Diamond-MSI K8N Neo4 Plat-MSI-K8N NeoF]
Hybrid View
    tebibyte L'avatar di asphalt
    Sep 2004
    Predefinito MSI Nforce4[MSI K8N Diamond-MSI K8N Neo4 Plat-MSI-K8N NeoF]
    Ci siamo prime foto e dettagli..
    1) MSI K8N dia. moon
    Socket 939 for AMD Athlon 64 and Athlon 64 FX processor
    Chip set: Nvidia nForce 4 SLI chip set
    Hypertransport: 1000MHz
    MEMORY type: 4x dual GDR 400
    Pci e x16 (SLI ready), 3x PCI 2.3
    7,1 Channel H/W audio
    Binarily Gigabit LAN
    4x SATA2 3Gb/s, RAID 0, 1, 0+1
    2x SATA2 3Gb/s, RAID 0, 1, 0+1
    10x USB 2.0
    3x IEEE1394
    ATX form Factor
    2)MSI K8N Neo4 Platinum
    Chip set: Nvidia nForce 4 Ultra chip set
    Pci e x16, 2x Pci e X1, 4x PCI 2.3
    7,1 Channel audio
    4x SATA2, RAID 0, 1, 0+1, 5
    10x USB 2.0
    2x IEEE1394
    ATX form Factor
    3)MSI K8N Neo4-F
    Socket 939 for Sempron, AMD Athlon 64 and Athlon 64 FX processor
    Chip set: Nvidia nForce 4 chip set
    7,1 Channel audio
    Gigabit LAN
    4x SATA2 RAID 0, 1, 0+1
    10x USB 2.0
    ATX form Factor
    Sep 2004
    PISA
    come mai ha l'Hyper Transport da 1Gh mentre Nforce 3 ultra ha quello da 2 GH
    http://www.nvitalia.com/stories.php?.../10/28/9651205
    Sep 2004
    Credo supporti l'Hypertransport: 2000MHz ma ad oggi non esiste ancora un processore AMD64 in grado di comunicare con la Ram con codeste caratteristiche.....immagino sia pronta per le prossime generazioni di processori..
    Riporto da AMD alcune caratteristiche:
    HyperTransport technology helps reduce the number of buses in a system, which can reduce system bottlenecks and enable today's faster microprocessors to use system memory more efficiently in high-end multiprocessor systems.
    Provide significantly more bandwidth than current technologies
    Use low-latency responses and low pin counts
    Maintain compatibility with legacy PC buses while being extensible to new SNA (Systems Network Architecture) buses.
    Appear transparent to operating systems and offer little impact on peripheral drivers.
    vedi thread "l'hypertransport da una mano al PCIexpress".
    Se sbaglio correggetemi.
  1. [Milano+SSin] MSI K8N-SLI Diamond
    By Flatline in forum -= Vendite : Hardware - Software =-
  2. [ROMA+sped] AMD64bit VENICE 3200+ & MSI K8N NEO4 PLATINUM
    By Ippo 2001 in forum -= Vendite : Hardware - Software =-
  3. Msi K8n Diamond nForce4 Sli - consiglio per l'acquisto
    By Dax in forum -= MotherBoards =-
  4. MSI K8N Diamond
    By Figus in forum -= Hardware generico =-
  5. MSI K8N Diamond (NVIDIA nForce4 SLI) Mainboard Review
    By ToXSysDwn in forum -= MotherBoards =-
