PS: dall´imagine che hai postato vedo che non vede nessun player....hai configurato R2?
Si, è configurato e funziona molto bene, resampling a 384k e conversione in PWM. L'immagine l'ho presa mentre il Raspi non era riavviato.
Nel log dello scanner ho visto che nella seconda riga c'è qualcosa che non va, a che fare con la mancata scansione?
[20-05-28 16:41:17.9970] main::main (206) Starting Logitech Media Server scanner (v8.0.0, 1590504530, Tue May 26 17:18:56 CEST 2020) perl 5.028001
[20-05-28 16:41:18.2755] Slim::Schema::forceCommit (2157) Warning: Trying to commit transactions before DB is initialized!
[20-05-28 16:41:18.4746] Slim::Music::Import::runImporter (577) Starting Slim::Media::MediaFolderScan scan
[20-05-28 16:41:18.4751] Slim::Utils::Scanner::Local::rescan (179) Discovering audio files in /sharedfolders/Musica
[20-05-28 16:41:18.6049] Slim::Utils::Scanner::Local::__ANON__ (191) Start processing found tracks
[20-05-28 16:41:18.6053] Slim::Utils::Scanner::Local::__ANON__ (199) Connect do DB
[20-05-28 16:41:18.6055] Slim::Utils::Scanner::Local::__ANON__ (202) Get latest ID
[20-05-28 16:41:18.6060] Slim::Utils::Scanner::Local::__ANON__ (224) Delete temporary table if exists
[20-05-28 16:41:18.6064] Slim::Utils::Scanner::Local::__ANON__ (227) Re-build temporary table
[20-05-28 16:41:18.6071] Slim::Utils::Scanner::Local::__ANON__ (276) Get deleted tracks count
[20-05-28 16:41:18.6074] Slim::Utils::Scanner::Local::__ANON__ (283) Get new tracks count
[20-05-28 16:41:18.6079] Slim::Utils::Scanner::Local::__ANON__ (288) Get changed tracks count
[20-05-28 16:41:18.6083] Slim::Utils::Scanner::Local::deleteTracks (519) Removing deleted audio files (0)
[20-05-28 16:41:18.6086] Slim::Utils::Scanner::Local::__ANON__ (301) Scanning new audio files (0)
[20-05-28 16:41:18.6089] Slim::Utils::Scanner::Local::__ANON__ (381) Rescanning changed audio files (0)
[20-05-28 16:41:18.6094] Slim::Music::Import::endImporter (710) Completed Slim::Media::MediaFolderScan Scan in 0 seconds.
[20-05-28 16:41:18.6115] Slim::Music::Import::runImporter (577) Starting Slim::Plugin::ExtendedBrowseModes::Libraries scan
[20-05-28 16:41:18.6121] Slim::Music::Import::runImporter (577) Starting Slim::Plugin::FullTextSearch::Plugin scan
[20-05-28 16:41:18.6132] Slim::Plugin::FullTextSearch::Plugin::_rebuildIndex (413) Starting fulltext index build
[20-05-28 16:41:18.6136] Slim::Plugin::FullTextSearch::Plugin::_rebuildIndex (417) Initialize fulltext table
[20-05-28 16:41:18.6152] Slim::Plugin::FullTextSearch::Plugin::_rebuildIndex (430) Create fulltext index for tracks
[20-05-28 16:41:18.6243] Slim::Plugin::FullTextSearch::Plugin::_rebuildIndex (440) Create fulltext index for albums
[20-05-28 16:41:18.6254] Slim::Plugin::FullTextSearch::Plugin::_rebuildIndex (449) Create fulltext index for contributors
[20-05-28 16:41:18.6264] Slim::Plugin::FullTextSearch::Plugin::_rebuildIndex (459) Create fulltext index for playlists
[20-05-28 16:41:18.6311] Slim::Plugin::FullTextSearch::Plugin::_rebuildIndex (494) Optimize fulltext index
[20-05-28 16:41:18.6415] Slim::Plugin::FullTextSearch::Plugin::_rebuildIndex (509) Fulltext index build done!
[20-05-28 16:41:18.6419] Slim::Music::Import::endImporter (710) Completed Slim::Plugin::FullTextSearch::Plugin Scan in 0 seconds.
[20-05-28 16:41:18.6424] Slim::Music::Import::runImporter (577) Starting Slim::Music::VirtualLibraries scan
[20-05-28 16:41:18.6613] Slim::Music::Import::endImporter (710) Completed Slim::Music::VirtualLibraries Scan in 0 seconds.
[20-05-28 16:41:18.6631] Slim::Music::Artwork::precacheAllArtwork (659) Starting precacheArtwork for 0 albums
[20-05-28 16:41:18.6636] Slim::Music::Import::endImporter (710) Completed precacheArtwork Scan in 0 seconds.
[20-05-28 16:41:18.6643] Slim::Music::Import::runScanPostProcessing (479) Starting Database optimization.
[20-05-28 16:41:18.7188] Slim::Music::Import::endImporter (710) Completed dbOptimize Scan in 0 seconds.
Sorry..ho eliminato la share con una installazione di Gentoo da zero.
Mi sono concentrato sul problema del mancato riavvio e ho trovato dove si blocca il reboot, e cioè dopo la selezione del DAC:
. system reboot: ok
. Enable/Disable Software: Squeezelite-R2 enable
. system reboot: ok
. Select Dac: Allo Piano 2.1 Hi-Fi Dac
- system reboot: Failed to load script info. Try to reload the page. Error message:
Failed to reconnect
provato e riprovato, si riproduce sempre lo stesso errore.
Forse qualcosa non gli piace nella combinazione Allo Reclocker + Allo Piano 2.1 DAC
Un'altra cosa, meno importante per ora. Nel config.txt:
arm_64bit=1
gpu_mem=16
dtparam=audio=off
audio_pwm_mode=2
disable_splash=1
hdmi_force_hotplug=1
dtparam=i2c_arm=on
dtparam=i2s=on
dtoverlay=allo-piano-dac-plus-pcm512x-audio
dtoverlay=pi3-disable-bt
#force_turbo=1
#max_usb_current=1
visto che uso il Reclocker per generare un master clock per rimediare ai noti problemi di jitter del raspi, dovrei aggiungere, ma aspetto conferma, questa riga:
dtoverlay=glb_mclk
gia vista p.e. nel config.txt di Volumio, e che all'ascolto faceva la differenza.
Buonasera a tutti,
sto notando una cosa forse bizzarra. Quando ascolto file in PCM ed effettuo la conversione in DSD grazie a sox le performance della cpu (un AMD Phenom XII 965 BE) sono più che soddisfacenti anche con DSD256 (e filtro sdm-8) mentre se il file è già un DSD ho uno dei quattro core della cpu costantemente al 100% (anche se sembra non aver conseguenze sul suono).
Il processo è questo:
/usr/bin/sox -q -t dff /mnt/audio/audio/DSD/1975 - Wish You Were Here SACD/01 - Pink Floyd - Shine On You Crazy Diamond (Parts I - V).dff -t dff -b 1 --buffer 8192 - lowpass -2 22000 gain -h rate -v -I -b 90.7 -f 11289600 sdm -f sdm-8
Banalmente pensavo che una conversione DSD -> DSD potessere essere meno gravosa di una PCM -> DSD. A cosa può essere dovuto secondo voi?
Ciao, Paolo.
Qualcuno mi sa dire se c'è un modo per disattivare il filtro passa basso in c-3po? Faccio upsampling e conversione a dsd256 con un rme adi 2 dac e ho dsd direct abilitato, il dac mi consente già di impostare un filtro a 50 o 150 khz.
Ultima modifica di 87mpi : 11-06-2020 a 18:54
@antonellocaroli
Su GP 2.13 x64 non riesco ad impostare un clocksource diverso da TSC.
Hpet è abilitato dal BIOS. Se provo ad abilitarlo dopo il reboot mi ritrovo di nuovo TSC. Acpi_pm lo stesso. Non ho il ramsystem abilitato il kernel è 5.4.13-rt-rt7-x86_64-GP-RT-ST
Grazie
Antonio
che risultato ti da
cat /etc/default/grub
e
cat /sys/devices/system/clocksource/clocksource0/available_clocksource
PS: ma sel primo rigo vedi solo TSC. Acpi_pm, vuol dire che sul tuo sistema sono gli uni due avviabili come dice anche la voce "Available Clocksource"
anche se il bios ti fa impostare hpet non vuole dire che il sistema lo supporti effettivamente...
Ultima modifica di antonellocaroli : 11-06-2020 a 20:24
