Originariamente inviato da
SimoneFil
codice:
cd /var/www/falcon/cgi
-bash: cd: /var/www/falcon/cgi: File o directory non esistente
Quindi ho fatto
codice:
cd /var/www/falcon/cgi-bin
./loadAudioCards.pl
e ho ottenuto:
codice:
root@ubuntu-Squeeze:/var/www/falcon/cgi-bin# ./loadAudioCards.pl
Can't locate CGI.pm in @INC (you may need to install the CGI module) (@INC contains: ../falcon/src ../falcon/lib /var/www/falcon/cgi-bin /etc/perl /usr/local/lib/i386-linux-gnu/perl/5.22.2 /usr/local/share/perl/5.22.2 /usr/lib/i386-linux-gnu/perl5/5.22 /usr/share/perl5 /usr/lib/i386-linux-gnu/perl/5.22 /usr/share/perl/5.22 /usr/local/lib/site_perl /usr/lib/i386-linux-gnu/perl-base .) at ../falcon/src/WebInterface/Utils.pm line 30.
BEGIN failed--compilation aborted at ../falcon/src/WebInterface/Utils.pm line 30.
Compilation failed in require at ../falcon/src/WebInterface/Configuration.pm line 32.
BEGIN failed--compilation aborted at ../falcon/src/WebInterface/Configuration.pm line 32.
Compilation failed in require at ../falcon/src/WebInterface/Controller.pm line 30.
BEGIN failed--compilation aborted at ../falcon/src/WebInterface/Controller.pm line 30.
Compilation failed in require at ./loadAudioCards.pl line 40.
BEGIN failed--compilation aborted at ./loadAudioCards.pl line 40.
Manca una libreria, quale di preciso? Ho provato a fare un search tra i pacchetti includenza libcgi e perl ma ne sono venuti fuori una miriade
P.S. Per software che hanno come come target client minimali con distro altrettanto minimali non è buona idea testarli su O.S. pesanti e completi di ogni cosa come può essere ubuntu desktop; perchè includono già tutto loro!
