Gentoo: Installazione PC Server (HQPlayer, LMS ) e PC Player (NAA, Mpd, Squeezelite-R2)
Pagina 75 di 78
... 25 65 66 67 68 69 70 71 72 73 74 75 76 77 78 ultimo
Visualizzazione dei risultati da 741 a 750 su 773
  1. #741
    Aug 2011
    kibibyte L'avatar di Miclaud
    Dec 2010
    Scusa michele nelle opzioni del kernel in
    Processor type and features --->
    Processor family --->
    cosa scegli?
    pui postare il make.conf? /etc/portage/make.conf
    Ho provato sia con "native optimizations autodetected by GCC" che con "Geode GX/LX"
    Il mio make.conf è il seguente:
    codice:
    # These settings were set by the catalyst build script that automatically
    # built this stage.
    # Please consult /usr/share/portage/config/make.conf.example for a more
    # detailed example.
    CHOST="i486-pc-linux-gnu"
    CFLAGS="-Os -pipe -march=geode -mmmx -m3dnow -fomit-frame-pointer"
    CXXFLAGS="${CFLAGS}"
    # WARNING: Changing your CHOST is not something that should be done lightly.
    # Please consult https://wiki.gentoo.org/wiki/Changin...CHOST_variable before changing.
    # NOTE: This stage was built with the bindist Use flag enabled
    PORTDIR="/usr/portage"
    DISTDIR="/usr/portage/distfiles"
    PKGDIR="/usr/portage/packages"
    # This sets the language of build output to English.
    # Please keep this setting intact when reporting bugs.
    LC_MESSAGES=C
    MAKEOPTS="-j1"
    #ABI_X86="32"
    #ACCEPT_KEYWORDS="amd64"
    ACCEPT_KEYWORDS="x86"
    ACCEPT_LICENSE="*"
    INPUT_DEVICES="evdev"
    VIDEO_CARDS="geode"
    USE="a52 aac aacplus alsa bindist consolekit corefonts dbus encode faac ffmpeg flac freesound g3dvl gudev hwdb icu id3 id3tag lame libsamplerate lv2 mad midi minizip mp3 mp4 mpeg mpg123 musepack policykit $
    GENTOO_MIRRORS="http://gentoo.c3sl.ufpr.br/ http://ftp.fi.muni.cz/pub/linux/gentoo/"
    CPU_FLAGS_X86="3dnow 3dnowext mmx mmxext"
  3. #743
    Aug 2011
    Puoi anche postare il risultato di
    codice:
    grep -m1 -A3 "vendor_id" /proc/cpuinfo
    e
    codice:
    grep lm /proc/cpuinfo
    v. anche il mio messaggio di sopra
  4. #744
    Dec 2010
    codice:
    codice:
    vendor_id	: AuthenticAMD
    cpu family	: 5
    model		: 10
    model name	: Geode(TM) Integrated Processor by AMD PCS
    codice:
    Questo non mi restituisce nulla. Altrimenti con cat /proc/cpuinfo ho:
    codice:
    processor	: 0
    cpu family	: 5
    model		: 10
    stepping	: 2
    cpu MHz		: 498.020
    cache size	: 128 KB
    physical id	: 0
    siblings	: 1
    core id		: 0
    cpu cores	: 1
    apicid		: 0
    initial apicid	: 0
    fdiv_bug	: no
    f00f_bug	: no
    coma_bug	: no
    fpu		: yes
    fpu_exception	: yes
    cpuid level	: 1
    wp		: yes
    flags		: fpu de pse tsc msr cx8 sep pge cmov clflush mmx mmxext 3dnowext 3dnow eagerfpu 3dnowprefetch vmmcall
    bugs		: sysret_ss_attrs
    bogomips	: 996.04
    clflush size	: 32
    cache_alignment	: 32
    address sizes	: 32 bits physical, 32 bits virtual
    power management:
    Ho cercato l'errore ovunque nei forum. Di solito erano problemi dovuti a live cd errate. La stage dovrebbe essere giusta altrimenti credo non potrei neanche fare il chroot, ad ogni modo ho preso la stage3-i486-20180323T214503Z.tar.xz da questo link:
    Index of /releases/x86/autobuilds/current-install-x86-minimal
    Ovviamente stiamo parlando del Futro con il Geode LX800
    Stasera proverò sul Praim che sta lavorando a casa (a quest'ora sarà ormai pronto per il genkernel). Per il praim, avendo un Atom, ho invece preso lo stage 3 per i686. Fino ad ora hanno dato lo stesso identico problema, speriamo bene...
  5. #745
    Aug 2011
    Hai provato anche con gentoo sources? eventualmente prova a chiedere nel forum di gentoo li sanno sicuro dove puó essere il problema...
    https://forums.gentoo.org/viewforum-f-23.html
  6. #746
    Dec 2010
    Proprio ora li stavo installando, vediamo che dice
    Intanto grazie mille! Se non va proviamo nei forum gentoo eventualmente
  7. #747
    Dec 2010
    Niente, anche il gentoo-sources dà gli stessi problemi. Un vero rompicapo, ora appena riesco apro un thread e vediamo che dicono. Sarà utile per i posteri
  8. #748
    Aug 2011
    Originariamente inviato da Miclaud
    Se hai deselezionato in menuconfig "64bit kernel" ... e non va...ti possono aiutare solo loro...e sono curioso anche io...
  9. #749
    tebibyte L'avatar di UnixMan
    Sep 2013
    Mmmh, attenzione che ci sono varie feature che dipendono dall'opzione kernel a 64bit e, se per caso sono attive, riattivano automaticamente anche quella. Inoltre, scegli correttamente il tipo di architettura/CPU per cui compilare.
    BTW: la compilazione la stai facendo direttamente sulla macchina per la quale produci il kernel, o su un'altra?
    Ciao, Paolo.
  10. #750
    Dec 2010
    Ciao Unix, quanto tempo
    La compilazione la sto facendo sulla macchina, ho voluto evitare la cross-compilazione per andare sul sicuro (e invece...).
    Ho provato selezionando varie cpu (Geode per il Futro, Atom e Pentium 4 per il Praim). Ho visto che stanno iniziando a rispondere nel forum, anche se per ora non è saltato fuori nulla di nuovo. Se siete curiosi di seguire c'è qui il thread (dove descrivo più approfonditamente il mio ambiente di compilazione): https://forums.gentoo.org/viewtopic-...4.html#8205734
    Proprio in questo momento sto per lanciare la compilazione sul Praim che ho a casa, con il kernel pf-sources. Vediamo come va anche se pure io sospetto che sia qualche opzione strana che va a richiedere il supporto per X64.
Pagina 75 di 78
