Trovato... Ca***ta mia, da me va perchè ho associato il perl come programma di apertura automatica.
Lo testo e se funziona ti dico come sistemare.
Ultima modifica di marcoc1712 : 28-10-2015 a 21:24
Ciao, Marco.
@Filippo, sostituisci l'attuale codice dello script con questo e ricompila, dovrebbe risolvere.
Fammi sapere.codice:@ECHO OFF SETLOCAL @rem Perl %~dp0\..\..\C-3PO.pl %* @rem Perl %~dp0C-3PO.pl %* for /f "tokens=*" %%a in ('Perl %~dp0\..\..\C-3PO.pl %*') do ( set VAR=%%a ) @rem echo %VAR% %VAR%
Ciao.
Ciao, Marco.
Il file cosi non si apre piú...ma il resample max sincro cmnq non va
questo nel log
codice:[15-10-28 21:36:40.8651] Slim::Player::TranscodingHelper::enabledFormat (223) Testing wav-flc-*-* vs flc-pcm-*-50:e5:49:cc:b4:29 [15-10-28 21:36:40.8652] Slim::Player::TranscodingHelper::checkBin (250) enabled [15-10-28 21:36:40.8652] Slim::Player::TranscodingHelper::checkBin (252) Found command: [C-3PO] -c $CLIENTID$ -p "C:\ProgramData\Squeezebox\prefs\plugin\C3PO.prefs" -i flc -o wav $START$ $END$ $RESAMPLE$ $FILE$ [15-10-28 21:36:40.8654] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->pcm via: [C-3PO] -c $CLIENTID$ -p "C:\ProgramData\Squeezebox\prefs\plugin\C3PO.prefs" -i flc -o wav $START$ $END$ $RESAMPLE$ $FILE$ [15-10-28 21:36:40.8655] Slim::Player::Song::open (408) Transcoder: streamMode=F, streamformat=pcm [15-10-28 21:36:40.8657] Slim::Player::TranscodingHelper::tokenizeConvertCommand2 (617) Using command for conversion: "C:\PROGRA~2\SQUEEZ~1\server\Plugins\C3PO\Bin\MSWin32-x86-multi-thread\C-3PO.exe" -c 50-e5-49-cc-b4-29 -p "C:\ProgramData\Squeezebox\prefs\plugin\C3PO.prefs" -i flc -o wav "C:\Users\filippo\Desktop\Music\David Virelles - Continuum (2012) [FLAC] {Pi Recordings}\09 - A Celebration, circa 1836.flac" | [15-10-28 21:36:40.8658] Slim::Player::Song::open (558) Tokenized command: "C:\PROGRA~2\SQUEEZ~1\server\Plugins\C3PO\Bin\MSWin32-x86-multi-thread\C-3PO.exe" -c 50-e5-49-cc-b4-29 -p "C:\ProgramData\Squeezebox\prefs\plugin\C3PO.prefs" -i flc -o wav "C:\Users\filippo\Desktop\Music\David Virelles - Continuum (2012) [FLAC] {Pi Recordings}\09 - A Celebration, circa 1836.flac" | [15-10-28 21:36:40.8913] Slim::Player::SongStreamController::new (31) live=1 [15-10-28 21:36:40.8916] Slim::Player::StreamingController::_Stream (1277) 50:e5:49:cc:b4:29: stream [15-10-28 21:36:40.8928] Slim::Player::StreamingController::_Stream (1314) Song queue is now 0 [15-10-28 21:36:40.8929] Slim::Player::StreamingController::_setPlayingState (2366) new playing state BUFFERING [15-10-28 21:36:40.8930] Slim::Player::StreamingController::_setStreamingState (2375) new streaming state STREAMING [15-10-28 21:36:40.8931] Slim::Player::StreamingController::_eventAction (303) 50:e5:49:cc:b4:29: NextTrackReady - new state BUFFERING-STREAMING [15-10-28 21:36:40.8932] Slim::Player::StreamingController::_eventAction (303) 50:e5:49:cc:b4:29: Play - new state BUFFERING-STREAMING [15-10-28 21:36:40.9279] Slim::Player::TranscodingHelper::enabledFormat (209) Checking to see if flc-flc-*-* is enabled [15-10-28 21:36:40.9280] Slim::Player::TranscodingHelper::enabledFormat (217) There are 6 disabled formats... [15-10-28 21:36:40.9281] Slim::Player::TranscodingHelper::enabledFormat (223) Testing aif-aif-*-* vs flc-flc-*-* ------------------------------------------------------------------------------------------------------------------------------- [15-10-28 21:36:40.9340] Slim::Player::TranscodingHelper::checkBin (250) enabled [15-10-28 21:36:40.9341] Slim::Player::TranscodingHelper::checkBin (252) Found command: [C-3PO] -c $CLIENTID$ -p "C:\ProgramData\Squeezebox\prefs\plugin\C3PO.prefs" -i flc -o wav $START$ $END$ $RESAMPLE$ $FILE$ [15-10-28 21:36:40.9343] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->pcm via: [C-3PO] -c $CLIENTID$ -p "C:\ProgramData\Squeezebox\prefs\plugin\C3PO.prefs" -i flc -o wav $START$ $END$ $RESAMPLE$ $FILE$ [15-10-28 21:36:40.9345] Slim::Player::TranscodingHelper::enabledFormat (209) Checking to see if flc-flc-*-* is enabled [15-10-28 21:36:40.9346] Slim::Player::TranscodingHelper::enabledFormat (217) There are 6 disabled formats... [15-10-28 21:36:40.9347] Slim::Player::TranscodingHelper::enabledFormat (223) Testing aif-aif-*-* vs flc-flc-*-* [15-10-28 21:36:40.9348] Slim::Player::TranscodingHelper::enabledFormat (223) Testing aif-flc-*-* vs flc-flc-*-* [15-10-28 21:36:40.9349] Slim::Player::TranscodingHelper::enabledFormat (223) Testing flc-aif-*-* vs flc-flc-*-* [15-10-28 21:36:40.9349] Slim::Player::TranscodingHelper::enabledFormat (223) Testing flc-flc-*-* vs flc-flc-*-* [15-10-28 21:36:40.9350] Slim::Player::TranscodingHelper::enabledFormat (227) ** flc-flc-*-* Disabled ** [15-10-28 21:36:40.9351] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: flc-dsf-squeezelite-50:e5:49:cc:b4:29 [15-10-28 21:36:40.9352] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: flc-dsf-*-50:e5:49:cc:b4:29 [15-10-28 21:36:40.9353] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: flc-dsf-squeezelite-* [15-10-28 21:36:40.9354] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: flc-dsf-*-* [15-10-28 21:36:40.9356] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: flc-dff-squeezelite-50:e5:49:cc:b4:29 [15-10-28 21:36:40.9356] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: flc-dff-*-50:e5:49:cc:b4:29 [15-10-28 21:36:40.9357] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: flc-dff-squeezelite-* [15-10-28 21:36:40.9358] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: flc-dff-*-* [15-10-28 21:36:40.9359] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: flc-alc-squeezelite-50:e5:49:cc:b4:29 ---------------------------------------------------------------------------------------------------------------- [15-10-28 21:36:40.9406] Slim::Player::TranscodingHelper::enabledFormat (223) Testing wav-flc-*-* vs flc-pcm-*-50:e5:49:cc:b4:29 [15-10-28 21:36:40.9407] Slim::Player::TranscodingHelper::checkBin (250) enabled [15-10-28 21:36:40.9408] Slim::Player::TranscodingHelper::checkBin (252) Found command: [C-3PO] -c $CLIENTID$ -p "C:\ProgramData\Squeezebox\prefs\plugin\C3PO.prefs" -i flc -o wav $START$ $END$ $RESAMPLE$ $FILE$ [15-10-28 21:36:40.9409] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->pcm via: [C-3PO] -c $CLIENTID$ -p "C:\ProgramData\Squeezebox\prefs\plugin\C3PO.prefs" -i flc -o wav $START$ $END$ $RESAMPLE$ $FILE$ [15-10-28 21:36:41.1809] Slim::Player::Source::_readNextChunk (350) Read to end of file or pipe [15-10-28 21:36:41.1811] Slim::Player::Source::_readNextChunk (373) end of file or error on socket, song pos: 0 [15-10-28 21:36:41.1813] Slim::Player::Source::_readNextChunk (378) 50:e5:49:cc:b4:29 mark end of stream [15-10-28 21:36:41.1814] Slim::Player::Source::_readNextChunk (386) Didn't stream any bytes for this song; mark it as failed [15-10-28 21:36:41.1815] Slim::Player::StreamingController::playerStreamingFailed (2237) 50:e5:49:cc:b4:29 [15-10-28 21:36:41.1817] Slim::Player::StreamingController::_playersMessage (789) Problema: impossibile aprire il file per:: file:///C:/Users/filippo/Desktop/Music/David%20Virelles%20-%20Continuum%20(2012)%20[FLAC]%20%7BPi%20Recordings%7D/09%20-%20A%20Celebration,%20circa%201836.flac [15-10-28 21:36:41.1822] Slim::Player::StreamingController::_eventAction (271) 50:e5:49:cc:b4:29: StreamingFailed in BUFFERING-STREAMING -> Slim::Player::StreamingController::_StopNextIfMore [15-10-28 21:36:41.1823] Slim::Player::StreamingController::_eventAction (284) params: errorDisconnect => undef [15-10-28 21:36:41.1825] Slim::Player::StreamingController::_Stop (603) Song queue is now 0 [15-10-28 21:36:41.1827] Slim::Player::SongStreamController::DESTROY (44) DESTROY(Slim::Player::SongStreamController=HASH(0xa1e76dc)) live=0 [15-10-28 21:36:41.1828] Slim::Player::StreamingController::_setPlayingState (2366) new playing state STOPPED [15-10-28 21:36:41.1829] Slim::Player::StreamingController::_setStreamingState (2375) new streaming state IDLE [15-10-28 21:36:41.1830] Slim::Player::StreamingController::_willRetry (1403) no retry data [15-10-28 21:36:41.1831] Slim::Player::StreamingController::nextsong (882) The next song is number 0, was 0 [15-10-28 21:36:41.1832] Slim::Player::StreamingController::_eventAction (303) 50:e5:49:cc:b4:29: StreamingFailed - new state STOPPED-IDLE [15-10-28 21:36:41.1908] Slim::Player::StreamingController::_eventAction (271) 50:e5:49:cc:b4:29: StatusHeartbeat in STOPPED-IDLE -> Slim::Player::StreamingController::_NoOp [15-10-28 21:36:43.0403] Slim::Player::TranscodingHelper::enabledFormat (209) Checking to see if flc-flc-*-* is enabled [15-10-28 21:36:43.0404] Slim::Player::TranscodingHelper::enabledFormat (217) There are 6 disabled formats... ----------------------------------------------------------- [15-10-28 21:36:43.0462] Slim::Player::TranscodingHelper::enabledFormat (223) Testing wav-flc-*-* vs flc-pcm-*-50:e5:49:cc:b4:29 [15-10-28 21:36:43.0463] Slim::Player::TranscodingHelper::checkBin (250) enabled [15-10-28 21:36:43.0464] Slim::Player::TranscodingHelper::checkBin (252) Found command: [C-3PO] -c $CLIENTID$ -p "C:\ProgramData\Squeezebox\prefs\plugin\C3PO.prefs" -i flc -o wav $START$ $END$ $RESAMPLE$ $FILE$ [15-10-28 21:36:43.0465] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->pcm via: [C-3PO] -c $CLIENTID$ -p "C:\ProgramData\Squeezebox\prefs\plugin\C3PO.prefs" -i flc -o wav $START$ $END$ $RESAMPLE$ $FILE$ [15-10-28 21:36:43.0468] Slim::Player::TranscodingHelper::enabledFormat (209) Checking to see if flc-flc-*-* is enabled [15-10-28 21:36:43.0469] Slim::Player::TranscodingHelper::enabledFormat (217) There are 6 disabled formats... [15-10-28 21:36:43.0469] Slim::Player::TranscodingHelper::enabledFormat (223) Testing aif-aif-*-* vs flc-flc-*-* [15-10-28 21:36:43.0470] Slim::Player::TranscodingHelper::enabledFormat (223) Testing aif-flc-*-* vs flc-flc-*-* [15-10-28 21:36:43.0471] Slim::Player::TranscodingHelper::enabledFormat (223) Testing flc-aif-*-* vs flc-flc-*-* [15-10-28 21:36:43.0472] Slim::Player::TranscodingHelper::enabledFormat (223) Testing flc-flc-*-* vs flc-flc-*-* [15-10-28 21:36:43.0473] Slim::Player::TranscodingHelper::enabledFormat (227) ** flc-flc-*-* Disabled ** [15-10-28 21:36:43.0474] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: flc-dsf-squeezelite-50:e5:49:cc:b4:29 ----------------------------------------------------------------------------------------- [15-10-28 21:36:43.0526] Slim::Player::TranscodingHelper::enabledFormat (223) Testing wav-flc-*-* vs flc-pcm-*-50:e5:49:cc:b4:29 [15-10-28 21:36:43.0527] Slim::Player::TranscodingHelper::checkBin (250) enabled [15-10-28 21:36:43.0528] Slim::Player::TranscodingHelper::checkBin (252) Found command: [C-3PO] -c $CLIENTID$ -p "C:\ProgramData\Squeezebox\prefs\plugin\C3PO.prefs" -i flc -o wav $START$ $END$ $RESAMPLE$ $FILE$ [15-10-28 21:36:43.0529] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->pcm via: [C-3PO] -c $CLIENTID$ -p "C:\ProgramData\Squeezebox\prefs\plugin\C3PO.prefs" -i flc -o wav $START$ $END$ $RESAMPLE$ $FILE$ [15-10-28 21:36:45.0014] Slim::Player::StreamingController::_eventAction (271) 50:e5:49:cc:b4:29: StatusHeartbeat in STOPPED-IDLE -> Slim::Player::StreamingController::_NoOp [15-10-28 21:36:50.0011] Slim::Player::StreamingController::_eventAction (271) 50:e5:49:cc:b4:29: StatusHeartbeat in STOPPED-IDLE -> Slim::Player::StreamingController::_NoOp
guarda nella cartella dei log del sever, dovresti avere un file C3PO.log con il comando effettivamente inviato o la condizione di errore, quello che vedo è tutto giusto, bisogna capire se lo script parte effettivamente o meno.
Due domande ovvie ma...
a. Hai eliminato il vecchio dalla cartella Bin o Bin/MSWin32-x86-multi-thread del server?
b. Hai messo la versione compilata (.exe) nella cartella /...C3PO/Bin/MSWin32-x86-multi-thread?
Ciao, Marco.
Ciao, Marco.
Fatto, solita procedura.
p.s.
Se ti serve, salvati ffMPEG, dalle prossime release NON lo includerò più, problemi di termini di licenza, anche se è liberamente scaricabile dal loro sito.
Ciao, Marco.
Tra la correzione di un bug e l'altra...
info => {
audio_offset => 80,
audio_size => 136956960,
bitrate => 8467200,
bits_per_sample => 24,
block_align => 6,
channels => 2,
file_size => 136957040,
format => 65534,
jenkins_hash => 3704618135,
samplerate => 176400,
song_length_ms => 7660,
Tutte le applicazioni compresa file e mediainfo mi riportano tutto normale, prima di usare hexdump mi sono estrapolato il 'pezzo' di LMS che fa le verifiche e questo è il risultato: L'offset è di 80 byte e non di 44, come normalmente è... che c... ci mette SOX in qui 36 byte in più...
con calma ci guardo, ma se qualcuno ha idee...
Ciao, Marco.
@DacPassion: Hai una versione rivista anche per mac, dovrebbe correggere il problema della massima frequenza e fare quello che ti aspetti, da me - comunque - rimane il problema del rumore bianco con resampling alla massima frequenza sincrona, potresti cortesemente provare anche quello e riferirmi?
Grazie.
@BigTube, @AntonelloCaroli. Credo di aver risolto i problemi che avevate, non appena potete cortesemente provate la nuova versione ed in particolare il resample a max frequenza sincrona.
Grazie.
Ultima modifica di marcoc1712 : 29-10-2015 a 13:58
Ciao, Marco.
