ok, TeamViewer scaricato per il mio OS Yosemite.
oggi prendo un Micro SD e una pendrive per masterizzare le SD.
magari ci si sente in MP.
grazie
Ultima modifica di robertorossi : 21-12-2019 a 08:00
Ciao from switzerland!
I can only respond in english but google chrome translate has gotten quite good at translating all websites
I used Gentooplayer to set it up on a Metrum Ambre (based on Raspberry 3) to work as a NAA with HQPlayer and with Audirvana (Mac) over Upnp. I've compared both settings. To me, HQPlayer over NAA is more stable and has a lot less "background noise". With Audirvana and Upnp I'm getting a constant increase in background noise, which is especially noticeable in quite music passages. Has anyone else experienced this? Or are there any settings that might improve this background noise?
Gracie!
No profiles, 4.19.81-GentooPlayer-4.19-ST+
I use the 32bit version from here: https://audiophilestyle.com/forums/t...omment-1015617
I will try to use the 4.14 kernel
Edit:
Just checked: in the newest version it is not available, only 4.19 kernels.
Ciao Filippo ho visto che la data della versione x86 è piuttosto vecchia ed è quella che sto usando.
Volevo sapere se la possibilità di setting via web è solo per raspy o per tutte le versioni.
E se basta dare gp-update per averla o bisogna caricare una versione nuova e se quella in download la implementa?
Saluti e buone feste.
Stefano
