C3PO Plugin verisone 0.1alfa
Pagina 52 di 52
... 2 42 43 44 45 46 47 48 49 50 51 52
Visualizzazione dei risultati da 511 a 514 su 514
  1. #511
    Aug 2011
    Log LMS spedito....
  2. #512
    Jan 2013
    Ciao,
    Non mi hai mandato le impostazioni del lettore e probabilmente l'arcano è li:
    [16-01-06 14:46:38.8299] Slim::Player::Song::open (408) Transcoder: streamMode=I, streamformat=pcm
    Sei con STDIN Abilitato, Giovanni era in SEEK abilitato, due percorsi completamente diversi.
    [16-01-06 14:46:38.8333] Slim::Player::Pipeline::new (96) Launching process with command: "C:\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\socketwrapper.exe" -D -i 60337 -o 60336 -c "\"C:\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\flac.exe\" -dcs --totally-silent -- - | \"C:\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\sox.exe\" -q -t wav - -t wav -r 384000 -c 2 -4 -s - gain -3 rate -v -M -a -b 90.7 384000"
    ...di nuovo lui...
    [16-01-06 14:46:38.8488] Slim::Player::StreamingController::_Stream (1265) 50:e5:49:cc:b4:29: stream
    [16-01-06 14:46:38.8498] Slim::Player::StreamingController::_eventAction (303) 50:e5:49:cc:b4:29: Play - new state BUFFERING-STREAMING
    [16-01-06 14:46:39.0779] Slim::Player::StreamingController::playerTrackStarted (2177) 50:e5:49:cc:b4:29
    [16-01-06 14:46:39.0780] Slim::Player::StreamingController::_eventAction (271) 50:e5:49:cc:b4:29: Started in BUFFERING-STREAMING -> Slim::Player::StreamingController::_Playing
    [16-01-06 14:46:39.0781] Slim::Player::StreamingController::_setPlayingState (2354) new playing state PLAYING
    [16-01-06 14:46:39.0782] Slim::Player::StreamingController::_Playing (361) Song 2 has now started playing
    [16-01-06 14:46:39.0785] Slim::Player::StreamingController::_Playing (390) Song queue is now 2
    [16-01-06 14:46:39.0786] Slim::Player::StreamingController::_eventAction (303) 50:e5:49:cc:b4:29: Started - new state PLAYING-STREAMING
    [16-01-06 14:46:41.1986] Slim::Player::Pipeline::sysread (304) Attempting to write to pipeline writer
    [16-01-06 14:46:41.1988] Slim::Player::StreamingController::playerReadyToStream (2195) 50:e5:49:cc:b4:29
    [16-01-06 14:46:41.1990] Slim::Player::StreamingController::_eventAction (271) 50:e5:49:cc:b4:29: ReadyToStream in PLAYING-STREAMING -> Slim::Player::StreamingController::_NextIfMore
    [16-01-06 14:46:41.1991] Slim::Player::StreamingController::_setStreamingState (2363) new streaming state IDLE
    [16-01-06 14:46:41.1992] Slim::Player::StreamingController::nextsong (882) The next song is number 0, was 2
    [16-01-06 14:46:41.1993] Slim::Player::StreamingController::_eventAction (303) 50:e5:49:cc:b4:29: ReadyToStream - new state PLAYING-IDLE
    Il player ha inviato lo stop dop circa 2 secondi nel corso dei quali ha suonato.
    Su squeezelite-R2:
    [14:34:12.918239] sendRESP:202 RESP
    [14:34:13.102368] sendSTAT:171 STAT: STMs
    [14:34:13.102404] sendSTAT:171 STAT: STMt
    [14:34:14.103434] sendSTAT:171 STAT: STMt
    [14:34:14.891739] pcm_decode:237 reached end of audio
    [14:34:14.891807] decode_thread:99 decode complete
    [14:34:14.891845] sendSTAT:171 STAT: STMd
    [14:34:15.892559] sendSTAT:171 STAT: STMt
    [14:34:16.346174] process:494 strm
    [14:34:16.346202] process_strm:256 strm command t
    [14:34:16.346212] sendSTAT:171 STAT: STMt
    [14:34:17.347244] sendSTAT:171 STAT: STMt
    [14:34:18.348315] sendSTAT:171 STAT: STMt
    [14:34:19.349397] sendSTAT:171 STAT: STMt
    [14:34:20.350455] slimproto_run:679 output underrun
    [14:34:20.350484] sendSTAT:171 STAT: STMu
    [14:34:21.344241] process:494 strm
    [14:34:21.344272] process_strm:256 strm command t
    [14:34:21.344289] sendSTAT:171 STAT: STMt
    [14:34:22.345344] slimproto_run:689 output timeout
    [14:34:26.169743] slimproto_stop:920 slimproto stop
    Probabilmente gli orari assoluti non sono allineati, OK, ma non mi torna nemmeno il Delta relativo:
    Il server si ferma dopo 2.35 secondi squeezelite dopo 4.01, se le cose stanno così NON è squeezelite a fermare il server, ma il server che si ferma (senza fornire segnalazione) e squeezelite se ne accorge, si ferma e manda la segnalazione.
    Sei comunque in pieno dominio di LMS, C-3PO ha finito il suo compito quando ha scritto la riga di comando. Potresti provare, per sicurezza, a scivere esattamente la stessa riga nel convert.conf e vedere che risultati ti da:
    flac pcm * *
    # IFRD:{RESAMPLE=-r %d}
    [flac] -dcs --totally-silent $START$ $END$ -- $FILE$ | [sox] -q -t wav - -t wav -r 384000 -c 2 -4 -s - gain -3 rate -v -M -a -b 90.7 384000
    Dovesse dare risultati diversi ne rimarrei molto sorpreso e, dovesse essere così, vedrei volentieri i log per capire cosa fa di diverso.
    Per chiarezza, però, questo NON è il problema riscontrato da Giovanni, lui è in Linux, non c'è SOCKETWRAPPER e per di più usa SEEK e non STDIN, potrebbe essere analogo, ma il log di squeezeite che ho visto è completamente diverso.
    A mio avviso stai però chiedendo troppo al tuo sistema e/o non hai buffer sufficientemente grandi (stai tenendo i buffer di default e sei a 384KHz/32 = 17.5 volte..). Proverei a seguire le indicazioni di calcolo che ho dato per i buffers e se non dovesse bastare passerei 24 bit e 192KHz, il che potrebbe rendere meno 'sensibile' Squeezelite-R2 a sbalzi del server, 'tamponando' sue lacune.
    Spero aiuti.
    EDIT: se non ricordo male, a te esce la finestra di SocketWrapper durante il debug, vedi se ci sono messaggi particolari li che non compiaono nel log del server.
    Ultima modifica di marcoc1712 : 06-01-2016 a 15:52
    Ciao, Marco.
  3. #513
    Aug 2011
    Ciao,
    ...di nuovo lui...
    Su squeezelite-R2:
    flac pcm * *
    Spero aiuti.
    La stringa non funziona uguale.
    credo che tu abbia centrato il problema nel mio caso....mettento a 192 non si presenta il problema....
    Quali erano le indicazioni sul calcolo del buffer? mi sfuggono....
  4. #514
    Jan 2013
    Qui.
    Ciao.
    Ciao, Marco.
Pagina 52 di 52
