Nuova versione per DDU (Display Driver Unistaller)
Pagina 5 di 7
1 2 3 4 5 6 7 ultimo
Visualizzazione dei risultati da 41 a 50 su 63
  1. #41
    Predefinito Display Driver Uninstaller 13.5.4.1
    Display Driver Uninstaller 13.5.4.1 (09 dicembre 2014)
    Changelog v.13.5.4.0:
    • Support AMD 14.12 OMEGA.
    • Activated Windows 10 Kernel 10 (Build 988x+).
    • Fix some possibles DDU freeze when cleaning.
    • Japanese language update. (DH.Omega)
    Update v.13.5.4.1 (re-uploaded)
    • Fixed an event log error caused by "paexec"
    • DDU can now run if .NET 4.0 is installed alone (mostly seen on Win XP)
    • Various installer\folders registry enhancements.
    download info ed home: Display Driver Uninstaller 13.5.4.1
  2. #42
    Predefinito Display Driver Uninstaller 13.5.4.2
    Display Driver Uninstaller 13.5.4.2 (16 dicembre 2014)
    Changelog:
    • Better SharedDlls cleanUP.
    • Do not kill explorer.exe in safe mode.
    • Tiny fixes/enhancements.
    fonte info e download: Display Driver Uninstaller 13.5.4.2
  3. #43
    nuova versione per l'utilissimo DDU
    Display Driver Uninstaller 13.5.5.0 (30 dicembre 2014)
    Changelog:
    • nVidia 347.09 support.
    • Microsoft Surface Pro 3 tested.
    • Fixed a possible bug when detecting the GPU details at launch.
    • Fixes/enhancements on the Cleanup engine (clsidleftover part).
    • Additional Intel/AMD notebook service cleanUP.
    download info ed home: Display Driver Uninstaller (DDU) 13.5.5.0
  4. #44
    Predefinito Display Driver Uninstaller 13.6.0.0
    DDU v.13.6.0.0 Changelog:
    • DDU will now log some of the deleted registry key. (work in progress)
    • New extended log window that show the log progress in realtime.
    • Additional AMD assembly cleanUP
    • Additional AMD cleanUP for older CAT version
    download: DDU Download
  5. #45
    Predefinito DDU v.13.6.1.1 (18 Gennaio 2015)
    ebbene si.. update!
    Changelog:
    • Fixed the "pnplockdown" cleanup part for Windows 7 (bug introduced on 13.6.x.x)
    • AMD additional files cleanup based on kevsamiga1974
    • Korean Language update.
    home ed info: DDU Download
  6. #46
    mi son distratto un attimo...colpa d'Alfredo!
    eccovi un breve riassunto degli ultimi rilasci
    D.D.U. v.13.6.2.0
    (data rilascio 22 Gennaio 2015)
    Changelog:
    • Support nVidia 347.25
    • Miracast service removal (nVidia)
    • Nv_cache cleanUP for the "Modern UI apps" (nVidia)
    • Additional MUI Cache Cleanup (nVidia)
    • Fixed some DDU crash on specific system configuration.
    D.D.U. v.13.6.3.0 (data rilascio 24 Gennaio 2015)
    Changelog:
    • Fixed a slow services removal under normal mode for nVidia. (order of removal)
    • Fix an issue opening webpage from the "?" menu.
    • Rewrite the SharedDlls cleanUP logic.
    • Fix a potential Null exception on the "deletedirectory" code
    • Now I log if we are in Safe Mode or not.
    • Fix OpenCL registry value removal for AMD Download
    D.D.U. v.13.6.4.0 (data rilascio 25 Gennaio 2015)
    Changelog:
    • Support nVidia iCafe 347.26
    • Small fixes / enhancements fixes
    mentre questa quì sotto è l'ultima release disponibile
    D.D.U. v.13.6.4.1 (data rilascio 30 Gennaio 2015)
    Changelog:
    • Support Windows 10 TP 9926
    • Korean language update (Zames Dean ,Contributor: 4Li)
    DDU v.13.6.4.2 (data rilascio 11 febbraio 2015)
    Changelog:
    • Additinal AMD cleanUP for older drivers (CrazY_Milojko)
    • Small additional nVidia CleanUP. (347.52 tested)
    • Changed the way DDU go into safemode with Windows 8+ (Troubleshoot-> advanced options -> startup Settings.)
    • Updated Russian and Ukraine Language
    DDU v.13.6.4.3 (data rilascio 19 febbraio 2015)
    Changelog:
    • Additional nVidia cleanup for WinXP32 based on CrazY_Milojko reports.
    • Fixed an issue on 32bit system that prevented some parts of Physx CleanUP.
    • (Thanks for CrazY_Milojko helping me noticing)
    • Fix an exception.
    • Removed some left over for AMD (Thanks: CrazY_Milojko )
    Ultima modifica di brugola.x : 04-03-2015 a 17:34
  7. #47
    Predefinito Display Driver Uninstaller v.14.0.0.0
    Display Driver Uninstaller v.14.0.0.0 (rilascio 25 Febbraio 2015)
    Changelog:
    • Updated the option menu.
    • DDU is now DPI Aware.
    Download Display Driver Uninstaller: DDU Download
    Ultima modifica di brugola.x : 04-03-2015 a 17:36
  8. #48
    Predefinito DDU v.14.0.0.1
    Display Driver Uninstaller v.14.0.0.1 (data rilascio 5 marzo 2015)
    Changelog:
    • Added a checkbox in the option window for booting directly into safemode from
    • windows 8+
    • Minor changes on the GPU removal procedure to fix an issue when cleaning in
    • normal mode when SLI is enabled.
    • Minor nVidia cleanUP addition
    • Esc key can now be use to close the options form.
    • Japanese Language update.
    • New Language : Bulgarian (Thanks : Ventsislav "Night_Raven" Dimitrov)
    • Added a message when a windows 8 user answer "yes" to reboot into safe Mode when direct Safe Mode is not ticked in the options.
    download info ed home: DDU Download
    PS: vi segnalo un "anomalia", quando sono andato a scaricare il file exe dal sito ufficiale di Wagnardmobile l'antivirus AVG mi avvisa della presenza di un exe in quanto tale..
    è la prima volta che mi rileva qualcosa di "strano", non mi è mai successo con DDU ma la metto io la mano sul fuoco, dal sito Wagnardmobile non abbiamo nulla da temere, scaricatelo ed utilizzatelo senza problemi
  9. #49
    Predefinito Display Driver Unistaller v.14.1.0.0
    update
    D.D.U. v.14.1.0.0 (data rilascio: 19 Marzo 2015)
    ChangeLog:
    • Added command lines arguments (thanks for the suggestion and testing FunkyMike)
    • (see readme.txt for the details)
    • nVidia addiditional CleanUP
    • Removed the bootmenu for win8+ (Users were confused by it)
    • Japanese and Serbian Language update. DH.Omega & CrazY_Milojko
    • Added a system tray icon for DDU
  10. #50
    Predefinito Display Driver Uninstaller v.14.2.0.0
    namo..
    DDU v.14.2.0.0 (data rilascio 30 Marzo 2015)
    Changelog:
    • NVIDIA SHIELD Wireless Controller Trackpad" Driver/files/service removal.
    • AMD cleanup update.
    • nVidia Cleanup Update.
    • Windows XP Cleanup update for both AMD / nVidia. (Thanks to CrazY_Milojko)
    • Translation update (Ukrainian). Thanks, Yurii Petrashko
    • Korean language update (Contributor: 4Li)
    • Changed the SVN link.
    • CleanUP fixes.
Pagina 5 di 7
