Guida a Logitech Media Server, Squeezelite e derivati.
Pagina 43 di 189
... 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 93 143 ... ultimo
Visualizzazione dei risultati da 421 a 430 su 1883
  1. #421
    tebibyte L'avatar di bigtube
    May 2012
    cagliari
    Ultima modifica di bigtube : 28-10-2015 a 13:44
  2. #422
    Jan 2013
    Plugin nuovo prelevato e aggiunto
    Non so io ti invio quello che mi torna cliccando su /var/log etc
    Tokenize non lo trovo
    il log C3PO in quale cartella ? in /var/log/squeezeboxserver non compare
    [15-10-28 00:22:05.0724] Data:ump::dump (100) Warning: "useC3PO: "
    [15-10-28 00:22:05.0732] Data:ump::dump (100) Warning: {
    capabilities => {
    D => "RESAMPLE=-r %d",
    F => "FILE=-f %f",
    R => "FILE=-f %F",
    T => "START=-s %s",
    U => "END=-w %w",
    command => "[C-3PO] -c \$CLIENTID\$ -p \"/var/lib/squeezeboxserver/prefs/plugin/C3PO.prefs\" -i wav -o wav \$START\$ \$END\$ \$RESAMPLE\$ \$FILE\$",
    profile => "wav-pcm-*-00:19:99:78:43:a5",
    [15-10-28 00:22:05.0734] Data:ump::dump (100) Warning: "useC3PO: "
    [15-10-28 00:22:05.0740] Data:ump::dump (100) Warning: {
    capabilities => {
    F => "FILE=-f %f",
    R => "FILE=-f %F",
    T => "START=-t %t",
    U => "END=-v %v",
    command => "[C-3PO] -c \$CLIENTID\$ -p \"/var/lib/squeezeboxserver/prefs/plugin/C3PO.prefs\" -i flc -o wav \$START\$ \$END\$ \$RESAMPLE\$ \$FILE\$",
    profile => "flc-pcm-*-00:19:99:78:43:a5",
    [15-10-28 00:22:05.1736] Data:ump::dump (100) Warning: "useC3PO: "
    [15-10-28 00:22:05.1741] Data:ump::dump (100) Warning: {
    capabilities => {
    F => "FILE=-f %f",
    R => "FILE=-f %F",
    T => "START=-s %s",
    U => "END=-w %w",
    [15-10-28 00:22:05.1743] Data:ump::dump (100) Warning: "useC3PO: "
    [15-10-28 00:22:05.1747] Data:ump::dump (100) Warning: {
    capabilities => {
    F => "FILE=-f %f",
    R => "FILE=-f %F",
    T => "START=-t %t",
    U => "END=-v %v",
    [15-10-28 00:22:05.2746] Data:ump::dump (100) Warning: "useC3PO: "
    [15-10-28 00:22:05.2750] Data:ump::dump (100) Warning: {
    capabilities => {
    F => "FILE=-f %f",
    R => "FILE=-f %F",
    T => "START=-s %s",
    U => "END=-w %w",
    [15-10-28 00:22:05.2752] Data:ump::dump (100) Warning: "useC3PO: "
    [15-10-28 00:22:05.2756] Data:ump::dump (100) Warning: {
    capabilities => {
    F => "FILE=-f %f",
    R => "FILE=-f %F",
    T => "START=-t %t",
    U => "END=-v %v",
    [15-10-28 00:22:05.3756] Data:ump::dump (100) Warning: "useC3PO: "
    [15-10-28 00:22:05.3761] Data:ump::dump (100) Warning: {
    capabilities => {
    F => "FILE=-f %f",
    R => "FILE=-f %F",
    T => "START=-s %s",
    U => "END=-w %w",
    [15-10-28 00:22:05.3763] Data:ump::dump (100) Warning: "useC3PO: "
    Molto meglio vero? ma incompleto.
    Ciao, Marco.
  3. #423
    May 2012
    cagliari
    boh vedi sopra il tuo post
  4. #424
    Jan 2013
    Se hai già clikkato su play almeno una volta, riavvia il server se non lo hai già fatto almeno una volta dopo aver installato il nuovo plugin.
    ALTRIMENTI:
    Postami per favore le informazioni sulla tua architettura (Settings, Info, Server status).
    Ciao, Marco.
  5. #425
    May 2012
    cagliari
    ALTRIMENTI:
    Sto lavorando con Debian 8.2 dando uname -a questo risulta sull'architettura del sistema :
    root@debian:~# uname -a
    Linux debian 4.2-4.dmz.1-liquorix-amd64 #1 ZEN SMP PREEMPT Debian 4.2-9 (2015-10-23) x86_64 GNU/Linux
    root@debian:~#
    Nella mia installazione su HD Debian ha la veste grafica Xfce . Ho installato L.M.S. dai repo ufficiali vers. 7.9.0( fatta con gdebi )
    Se manca qualcosa non lo so'
    Uso indifferentemente Lubuntu . Poi faccio la ricognizione anche con qello.
  6. #426
    Jan 2013
    root@debian:~#
    root@debian:~#
    Grazie, ma per non sbagliare e prendere fischi per fiaschi, potresti per favore postarmi quello che vedi in LMS -> Impostazioni -> Informazioni -> Stato del Server?
    Qualcosa di questo tipo:
    Logitech Media Server Versione: 7.9.0 - TRUNK @ UNKNOWN
    Nome host: pc
    Indirizzo IP del server: 192.168.1.103
    Porta HTTP server: 9000
    Sistema operativo: Windows XP - IT - cp1252
    Architettura piattaforma: 586
    Versione Perl: 5.14.1 - MSWin32-x86-multi-thread
    Audio::Scan: 0.95
    Versione database: DBD::SQLite 1.34_01 (sqlite 3.7.7.1)
    Totale lettori riconosciuti: 1
    Grazie.
    Ciao, Marco.
  7. #427
    May 2012
    cagliari
    Nome host: pc
    Audio::Scan: 0.95
    Grazie.
    ecce
    Logitech Media Server Version: 7.9.0 - 1444318731 @ Wed Oct 14 04:05:40 UTC 2015
    Hostname: giovanni-HP-Compaq-6000-Pro-MT-PC
    Server IP Address: 192.168.1.107
    Server HTTP Port Number: 9000
    Operating system: Debian - EN - utf8
    Platform Architecture: x86_64-linux
    Perl Version: 5.20.2 - x86_64-linux-gnu-thread-multi
    Audio::Scan: 0.95
    Database Version: DBD::SQLite 1.34_01 (sqlite 3.7.7.1)
    Total Players Recognized: 1
  8. #428
    Jan 2013
    ecce
    Audio::Scan: 0.95
    E' la stessa mia, a parte la versione del perl molto più avanzata per te, ma non credo sia quello.
    Vediamo di sfogliare la cipolla:
    Nella cartella del Plugin (dovrebbe essere /var/lib/squeezeboxserver/Plugins) hai:
    C3PO/Bin/x86_64-linux/C-3PO ? Ha i permessi di esecuzione corretti?
    puoi postarmi il contenuto del file /var/lib/squeezeboxserver/prefs/plugin/C3PO.prefs (occho a non modificarlo).
    Ciao, Marco.
  9. #429
    May 2012
    cagliari
    premesso che la cartella in cui ho messo C3PO originalmente è in /usr/share/squeezeboxserver/Plugins .....sara' questo il problema?
    nella cartella che hai citato: /var/lib/squeezeboxserver/Plugins non c'è niente
    _client:00:19:99:78:43:a5:
    _ts_aliasing: 1445595724
    _ts_bandwidth: 1445595724
    _ts_codecs: 1446026948
    _ts_dither: 1445595724
    _ts_gain: 1445595724
    _ts_id: 1445595724
    _ts_macaddress: 1445595724
    _ts_maxSupportedSamplerate: 1445595724
    _ts_model: 1445595724
    _ts_modelName: 1445595724
    _ts_name: 1445995771
    _ts_outBitDepth: 1445852300
    _ts_outByteOrder: 1445595724
    _ts_outChannels: 1445595724
    _ts_outCodec: 1445595724
    _ts_outEncoding: 1445595724
    _ts_phase: 1445595724
    _ts_quality: 1445852300
    _ts_resampleTo: 1445595724
    _ts_resampleWhen: 1445852300
    _ts_sampleRates: 1446026948
    _ts_useGlogalSettings: 1445595724
    _version: 0
    aliasing: on
    bandwidth: 907
    codecs:
    aif: ~
    dff: ~
    dsf: ~
    flc: on
    pcm: on
    dither: on
    gain: 3
    macaddress: 00:19:99:78:43:a5
    maxSupportedSamplerate: '384000'
    model: squeezelite
    modelName: SqueezeLite
    outBitDepth: '4'
    outByteOrder: L
    outChannels: 2
    outCodec: wav
    outEncoding: s
    phase: M
    quality: v
    resampleTo: S
    resampleWhen: A
    sampleRates:
    '11025': ~
    '12000': ~
    '16000': ~
    '176400': on
    '192000': ~
    '22050': ~
    '24000': ~
    '32000': ~
    '352800': on
    '384000': ~
    '44100': on
    '48000': ~
    '8000': ~
    '88200': on
    '96000': ~
    useGlogalSettings: on
    _ts_aliasing: 1445595721
    _ts_bandwidth: 1445595721
    _ts_dither: 1445595721
    _ts_gain: 1445595721
    _ts_outBitDepth: 1445852292
    _ts_outByteOrder: 1445595721
    _ts_outChannels: 1445595721
    _ts_outCodec: 1445595721
    _ts_outEncoding: 1445595721
    _ts_pathToC3PO: 1445999808
    _ts_pathToFFmpeg: 1445595721
    _ts_pathToFaad: 1445595721
    _ts_pathToFlac: 1445595721
    _ts_pathToSox: 1445595721
    _ts_phase: 1445595721
    _ts_quality: 1445852292
    _ts_resampleTo: 1445595721
    _ts_resampleWhen: 1445852292
    _ts_serverFolder: 1445852185
    _version: 0
    aliasing: on
    bandwidth: 907
    dither: on
    gain: 3
    outBitDepth: '4'
    outByteOrder: L
    outChannels: 2
    outCodec: wav
    outEncoding: s
    pathToC3PO: ~
    pathToFFmpeg: /usr/bin/ffmpeg
    pathToFaad: /usr/share/squeezeboxserver/Bin/x86_64-linux/faad
    pathToFlac: /usr/share/squeezeboxserver/Bin/x86_64-linux/flac
    pathToSox: /usr/share/squeezeboxserver/Bin/x86_64-linux/sox
    phase: M
    quality: v
    resampleTo: S
    resampleWhen: A
    serverFolder: /usr/sbin
  10. #430
    Jan 2013
    _ts_id: 1445595724
    _version: 0
    aliasing: on
    bandwidth: 907
    codecs:
    aif: ~
    dff: ~
    dsf: ~
    flc: on
    pcm: on
    dither: on
    gain: 3
    model: squeezelite
    outBitDepth: '4'
    outByteOrder: L
    outChannels: 2
    outCodec: wav
    outEncoding: s
    phase: M
    quality: v
    resampleTo: S
    resampleWhen: A
    sampleRates:
    '11025': ~
    '12000': ~
    '16000': ~
    '176400': on
    '192000': ~
    '22050': ~
    '24000': ~
    '32000': ~
    '352800': on
    '384000': ~
    '44100': on
    '48000': ~
    '8000': ~
    '88200': on
    '96000': ~
    _version: 0
    aliasing: on
    bandwidth: 907
    dither: on
    gain: 3
    outBitDepth: '4'
    outByteOrder: L
    outChannels: 2
    outCodec: wav
    outEncoding: s
    pathToC3PO: ~
    phase: M
    quality: v
    resampleTo: S
    resampleWhen: A
    Da me la seconda è un simlink alla prima, quindi non è un problema, ma non vorrei che fosse l'installazione del primo plugin a crearlo, non ne ho idea. Le direttive di LMS sono di metterli nella cartella che ti ho indicato, io farei una prova in quel modo.
    Tieni presente che in versione definitiva queste operazioni non saranno più necessarie.
    Ciao, Marco.
Pagina 43 di 189
