codice:
/usr/bin/squeezelite -b 3072:4096 -R -u vLE:::28 -m 5a:7f:c5:88:55:ae -h -c flac,pcm,mp3,ogg -r 44100,48000,88200,96000,176400,192000,352800,384000 -d all=info -f /run/spacd/c/2/l/0/squeezelite.log -o hw:2,0 -a 100:3:32:1 -p 45 -N /mnt/hdd/system/spac/JLsounds Hi-Rez Audio 2.0/device0/squeezelite.name -s 192.168.178.21
[16:26:57.417458] stream_init:290 init stream
[16:26:57.418344] output_init_alsa:817 init output
[16:26:57.418369] output_init_alsa:846 requested alsa_buffer: 100 alsa_period: 3 format: 32 mmap: 1
[16:26:57.418399] output_init_common:410 supported rates: 384000 352800 192000 176400 96000 88200 48000 44100
[16:26:57.425326] output_init_alsa:862 memory locked
[16:26:57.425416] decode_init:129 init decode, include codecs: flac,pcm,mp3,ogg exclude codecs:
[16:26:57.440343] load_vorbis:300 loaded libvorbisfile.so.3
[16:26:57.440360] register_vorbis:329 using vorbis to decode ogg
[16:26:57.455460] load_flac:258 loaded libFLAC.so.8
[16:26:57.455474] register_flac:286 using flac to decode flc
[16:26:57.455479] register_pcm:390 using pcm to decode aif,pcm
[16:26:57.464581] load_mad:383 loaded libmad.so.0
[16:26:57.464595] register_mad:412 using mad to decode mp3
[16:26:57.474662] load_soxr:268 loaded libsoxr.so.0
[16:26:57.474678] resample_init:361 resampling sync recipe: 0x06, flags: 0x00, scale: 0.89, precision: 28.0, passband_end: 0.00000, stopband_begin: 0.00000, phase_response: -1.0
[16:26:57.474715] slimproto:823 retrieved name JLsounds Hi-Rez Audio 2.0 from /mnt/hdd/system/spac/JLsounds Hi-Rez Audio 2.0/device0/squeezelite.name
[16:26:57.474733] slimproto:849 connecting to 192.168.178.21:3483
[16:26:57.474771] output_thread:638 open output device: hw:2,0
[16:26:57.474784] alsa_open:355 opening device at: 44100
[16:26:57.474868] alsa_open:406 opened device hw:2,0 using format: S32_LE sample rate: 44100 mmap: 1
[16:26:57.474894] alsa_open:485 buffer: 100 period: 3 -> buffer size: 4410 period size: 1470
[16:26:57.475080] slimproto:882 connected
[16:26:57.475089] sendHELO:124 mac: 5a:7f:c5:88:55:ae
[16:26:57.475094] sendHELO:126 cap: Model=squeezelite,AccuratePlayPoints=1,HasDigitalOut=1,HasPolarityInversion=1,Firmware=v1.8,ModelName=SqueezeLite,MaxSampleRate=384000,ogg,flc,aif,pcm,mp3
[16:26:57.536518] decode_flush:192 decode flush
[16:26:57.536528] output_flush:423 flush output buffer
[16:26:57.536611] decode_flush:192 decode flush
[16:26:57.536617] output_flush:423 flush output buffer
[16:26:57.676053] decode_flush:192 decode flush
[16:26:57.676080] output_flush:423 flush output buffer
[16:26:57.721390] codec_open:220 codec open: 'p'
[16:26:57.721405] pcm_open:371 pcm size: 2 rate: 44100 chan: 2 bigendian: 0
[16:26:57.721417] stream_sock:384 connecting to 192.168.178.21:9000
[16:26:57.722210] stream_sock:413 header: GET /stream.mp3?player=5a:7f:c5:88:55:ae HTTP/1.0
[16:26:57.820248] stream_thread:176 headers: len: 115
HTTP/1.1 200 OK
Server: Logitech Media Server (7.9.0 - 1443102866)
Connection: close
Content-Type: audio/L16
[16:26:57.865041] _check_header:77 WAVE
[16:26:57.865062] _check_header:101 header: fmt len: 40
[16:26:57.865067] _check_header:129 pcm size: 3 rate: 192000 chan: 2 bigendian: 0
[16:26:57.865071] _check_header:101 header: fact len: 4
[16:26:57.865075] _check_header:101 header: data len: 443765760
[16:26:57.865079] _check_header:107 audio size: 443765760
[16:26:57.865083] pcm_decode:198 setting track_start
[16:26:57.865087] resample_newstream:231 disable resampling - rates match
[16:26:57.865091] process_newstream:123 processing: inactive
[16:26:57.869357] _output_frames:61 start buffer frames: 86016
[16:26:57.869379] _output_frames:146 track start sample rate: 192000 replay_gain: 0
[16:26:57.879390] output_thread:638 open output device: hw:2,0
[16:26:57.889387] alsa_open:355 opening device at: 192000
[16:26:57.889521] alsa_open:406 opened device hw:2,0 using format: S32_LE sample rate: 192000 mmap: 1
[16:26:57.889542] alsa_open:485 buffer: 100 period: 3 -> buffer size: 19200 period size: 6400
[16:27:03.732942] decode_flush:192 decode flush
[16:27:03.732972] output_flush:423 flush output buffer
[16:27:03.759657] codec_open:220 codec open: 'p'
[16:27:03.759674] pcm_open:371 pcm size: 2 rate: 44100 chan: 2 bigendian: 0
[16:27:03.759687] stream_sock:384 connecting to 192.168.178.21:9000
[16:27:03.760497] stream_sock:413 header: GET /stream.mp3?player=5a:7f:c5:88:55:ae HTTP/1.0
[16:27:03.826580] stream_thread:176 headers: len: 115
HTTP/1.1 200 OK
Connection: close
[16:27:03.872647] _check_header:77 WAVE
[16:27:03.872661] _check_header:101 header: fmt len: 40
[16:27:03.872666] _check_header:129 pcm size: 3 rate: 192000 chan: 2 bigendian: 0
[16:27:03.872671] _check_header:101 header: fact len: 4
[16:27:03.872674] _check_header:101 header: data len: 443765760
[16:27:03.872678] _check_header:107 audio size: 443765760
[16:27:03.872682] pcm_decode:198 setting track_start
[16:27:03.872687] resample_newstream:231 disable resampling - rates match
[16:27:03.872691] process_newstream:123 processing: inactive
[16:27:03.878874] _output_frames:61 start buffer frames: 89940
[16:27:03.878896] _output_frames:146 track start sample rate: 192000 replay_gain: 0
[16:31:09.351053] decode_flush:192 decode flush
[16:31:09.351086] output_flush:423 flush output buffer
[16:31:09.354416] decode_flush:192 decode flush
[16:31:09.354424] output_flush:423 flush output buffer
[16:31:09.382317] codec_open:220 codec open: 'p'
[16:31:09.382325] pcm_open:371 pcm size: 2 rate: 44100 chan: 2 bigendian: 0
[16:31:09.382338] stream_sock:384 connecting to 192.168.178.21:9000
[16:31:09.383160] stream_sock:413 header: GET /stream.mp3?player=5a:7f:c5:88:55:ae HTTP/1.0
[16:31:09.422650] stream_thread:176 headers: len: 115
HTTP/1.1 200 OK
Connection: close
[16:31:09.557363] _check_header:77 WAVE
[16:31:09.557383] _check_header:101 header: fmt len: 40
[16:31:09.557388] _check_header:129 pcm size: 3 rate: 192000 chan: 2 bigendian: 0
[16:31:09.557392] _check_header:101 header: fact len: 4
[16:31:09.557396] _check_header:101 header: data len: 228587520
[16:31:09.557400] _check_header:107 audio size: 228587520
[16:31:09.557403] pcm_decode:198 setting track_start
[16:31:09.557408] resample_newstream:231 disable resampling - rates match
[16:31:09.557412] process_newstream:123 processing: inactive
[16:31:09.574816] _output_frames:61 start buffer frames: 217074
[16:31:09.574851] _output_frames:146 track start sample rate: 192000 replay_gain: 0
[16:31:16.259473] decode_flush:192 decode flush
[16:31:16.259505] output_flush:423 flush output buffer
[16:31:16.263223] decode_flush:192 decode flush
[16:31:16.263231] output_flush:423 flush output buffer
[16:31:16.288855] codec_open:220 codec open: 'p'
[16:31:16.288863] pcm_open:371 pcm size: 2 rate: 44100 chan: 2 bigendian: 0
[16:31:16.288876] stream_sock:384 connecting to 192.168.178.21:9000
[16:31:16.289712] stream_sock:413 header: GET /stream.mp3?player=5a:7f:c5:88:55:ae HTTP/1.0
[16:31:16.326077] stream_thread:176 headers: len: 115
HTTP/1.1 200 OK
Connection: close
[16:31:16.467056] _check_header:77 WAVE
[16:31:16.467075] _check_header:101 header: fmt len: 40
[16:31:16.467079] _check_header:129 pcm size: 3 rate: 192000 chan: 2 bigendian: 0
[16:31:16.467084] _check_header:101 header: fact len: 4
[16:31:16.467087] _check_header:101 header: data len: 443765760
[16:31:16.467091] _check_header:107 audio size: 443765760
[16:31:16.467095] pcm_decode:198 setting track_start
[16:31:16.467099] resample_newstream:231 disable resampling - rates match
[16:31:16.467103] process_newstream:123 processing: inactive
[16:31:16.474767] _output_frames:61 start buffer frames: 218681
[16:31:16.474800] _output_frames:146 track start sample rate: 192000 replay_gain: 0
[16:31:20.167378] decode_flush:192 decode flush
[16:31:20.167410] output_flush:423 flush output buffer
[16:31:20.170661] decode_flush:192 decode flush
[16:31:20.170669] output_flush:423 flush output buffer
[16:31:20.190501] codec_open:220 codec open: 'p'
[16:31:20.190513] pcm_open:371 pcm size: 2 rate: 44100 chan: 2 bigendian: 0
[16:31:20.190526] stream_sock:384 connecting to 192.168.178.21:9000
[16:31:20.191321] stream_sock:413 header: GET /stream.mp3?player=5a:7f:c5:88:55:ae HTTP/1.0
[16:31:20.232079] stream_thread:176 headers: len: 115
HTTP/1.1 200 OK
Connection: close
[16:31:20.373311] _check_header:77 WAVE
[16:31:20.373331] _check_header:101 header: fmt len: 40
[16:31:20.373335] _check_header:129 pcm size: 3 rate: 192000 chan: 2 bigendian: 0
[16:31:20.373340] _check_header:101 header: fact len: 4
[16:31:20.373344] _check_header:101 header: data len: 144906240
[16:31:20.373348] _check_header:107 audio size: 144906240
[16:31:20.373351] pcm_decode:198 setting track_start
[16:31:20.373356] resample_newstream:231 disable resampling - rates match
[16:31:20.373360] process_newstream:123 processing: inactive
[16:31:20.374741] _output_frames:61 start buffer frames: 218440
[16:31:20.374771] _output_frames:146 track start sample rate: 192000 replay_gain: 0
