C3PO Plugin verisone 0.1alfa
Pagina 37 di 52
... 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 ... ultimo
Visualizzazione dei risultati da 361 a 370 su 514
  1. #361
    Jul 2014
    [15-11-30 10:11:58.2426] Slim::bootstrap::tryModuleLoad (286) Warning: Module [Plugins::C3PO::Plugin] failed to load:
    Can't locate Plugins/C3PO/Plugin.pm in @INC (you may need to install the Plugins::C3PO::Plugin module) (@INC contains: /Users/ciccino/Library/Application Support/Squeezebox/Plugins/C-3PO-0.6-alpha/lib /Users/ciccino/Library/Caches/Squeezebox/InstalledPlugins /Library/PreferencePanes/Squeezebox.prefPane/Contents/server/CPAN/arch/5.18/darwin-thread-multi-2level /Library/PreferencePanes/Squeezebox.prefPane/Contents/server/CPAN/arch/5.18/darwin-thread-multi-2level/auto /Library/PreferencePanes/Squeezebox.prefPane/Contents/server/CPAN/arch/5.18.2/darwin-thread-multi-2level /Library/PreferencePanes/Squeezebox.prefPane/Contents/server/CPAN/arch/5.18.2/darwin-thread-multi-2level/auto /Library/PreferencePanes/Squeezebox.prefPane/Contents/server/CPAN/arch/darwin-thread-multi-2level /Library/PreferencePanes/Squeezebox.prefPane/Contents/server/CPAN/arch/5.18 /Library/PreferencePanes/Squeezebox.prefPane/Contents/server/lib /Library/PreferencePanes/Squeezebox.prefPane/Contents/server/CPAN /Library/PreferencePanes/Squeezebox.prefPane/Contents/server /Library/Application Support/Squeezebox /Users/ciccino/Library/Application Support/Squeezebox /Library/Perl/5.18/darwin-thread-multi-2level /Library/Perl/5.18 /Network/Library/Perl/5.18/darwin-thread-multi-2level /Network/Library/Perl/5.18 /Library/Perl/Updates/5.18.2 /System/Library/Perl/5.18/darwin-thread-multi-2level /System/Library/Perl/5.18 /System/Library/Perl/Extras/5.18/darwin-thread-multi-2level /System/Library/Perl/Extras/5.18 .) at (eval 1028) line 1.
    BEGIN failed--compilation aborted at (eval 1028) line 1.
    [15-11-30 10:11:58.2440] Slim::Utils::PluginManager::load (323) Error: Couldn't load Plugins::C3PO::Plugin
    [15-11-30 10:11:58.4679] Plugins::Qobuz::Plugin::BEGIN (46) Success: using Text::LevenshteinXS to speed Qobuz up.
  2. #362
    Jan 2013
    Ho messo la 0.6.0 su osx mi da caricamento plug in non riuscito
    A me funziona, ma mi sono accorto che la cartella compressa che scarichi da GitHub non contiene il primo livello (C3PO), quindi devi crearlo manualmente tu.
    Sistemerò la cosa, Verifica per cortesia se il motivo è quello.
    Ciao, Marco.
  3. #363
    Jan 2013
    Si, l'errore è quello, ti ha scaricato il plugin nella cartella:
    Grazie della segnalazione, per il momento puoi rinominarla in C3PO, nel frattempo correggo la cosa...
    Ciao, Marco.
  4. #364
    Jul 2014
    Fatto. ora il plugin viene caricato ma non lo vedo in avanzate e neanche nelle impostazioni del lettore
  5. #365
    Jan 2013
    mi pareva di aver già risposto, ma si è perso...
    Prova per cortesia a verificare se il plugin è attivo nelle impostazioni-> plugin. Forse lo ha caricato, ma non abilitato.
    Ciao, Marco.
  6. #366
    Jul 2014
    Risulta attivo, ma non mi compare nulla
  7. #367
    Jan 2013
    Probabilmente è rimasto sporco qualche cosa.
    Ti consiglio di cancellare la cartella e provare a reinstallare la versione che ho appena pubblicato su GitHub, dammi solo il tempo di modificare il link in testa.
    Ciao, Marco.
  8. #368
    Jan 2013
    Fatto!
    Ciao, Marco.
  9. #369
    Jul 2014
    Ok grazie!! Ora va sia in sincrona che massima sia con i file locali che con qobuz
  10. #370
    Jan 2013
    Perfetto.
    Hai modo di confrontare il mac con un altro Pc win o Linux? Te lo chiedo prchè a mio avviso mac ha qualcosa in più in termini di suono, di Win sicuro, di linux dipende dall'HW a mio avviso, i pc 'normali' perdono, la Alix vince.
    Ciao, Marco.
Pagina 37 di 52
