GPU-Z by TechPowerUp!
Pagina 3 di 10
1 2 3 4 5 6 7 8 9 10 ultimo
Visualizzazione dei risultati da 21 a 30 su 99
  1. #21
    • Added support for variants of i945G, Q35, G31/G33, G84, G92, G96, GT200, G86M, G84M, C79
    • Improved RV770 and GT200 detection code
    • Updated NVIDIA temperature reading code
    • Fixed updater getting stuck during refresh
    • CrossFire on Vista64 now reported with note "unsure", instead of just "unknown"
    • Added mini graph to sensors
    • Screenshots are uploaded as PNG now
    • Added crash report error handler
    • Updated G70 number of ROPs
    • Added PCI Vendor Point of View
    • Improved S3 Chrome 400, S20, S18 and S8 detection
    download gpu-z 0.2.2
  2. #22
    • Fixed NVIDIA GeForce GTX 260/280 (GT200) support. Everything is working and tested now
    • Removed bogus 190°C PCB temp sensor on various NVIDIA cards
    • Added fan speed monitoring for NVIDIA
    • Fixed crash when switching devices during sensor refresh
    • Fixed ROP/Shader count on NVIDIA G72
    • Fixed graphs spilling over their client area
    • Fixed a number of other rare crashes
    • NVIDIA device ID 0x00F3 now correctly recognized as NV43
    • Improved crash reporting module
    download diretto
  3. #23
    Eledh or life... L'avatar di DJnat
    Messina
    è valido anche per le vga vecchie? o solo quelle di nuova generazione?
    Intel i5 3570k|Zalman 8700|Asrock Z77 Extreme4|2x ATI Gainward HD4850 512mb GS|2x4gb Crucial Ballistix Tactical Tracer LED 1866mhz|2x Samsung 320gb Spinpoint F4|Crucial M4 64gb|Corsair HX650W|Corsair Carbide 500r|le mie trattative
  4. #24
    gibibyte L'avatar di Hyradus
    Aug 2006
    Roma (RM), Cori (LT)
    http://www.techpowerup.com/downloads/1104/mirrors.php
    • Improved RV770 detection
    • Fixed another crash related to sensors when switching cards
    • More measures to get rid of 190° PCB sensors
    • Added preliminary support for RV730
  5. #25
    Messina
    questo prog mi resta in esecuzione senza far niente
  6. #26
    Jan 2006
    Bergamo
    Parli di dell'ultima versione o tutte? Che sistema operativo hai?
  7. #27
    Messina
    adesso è partito...molto probabilmente devo proprio chiudere tutto per farlo partire(avevo un divx aperto)
  8. #28
    • Fixed BIOS Reading on HD 4870. Please do not flash non-128K BIOSes to GDDR5 cards
    • Fixed GDDR5 bandwidth calculation
    • Fixed texture fillrate on RV770 and RV730
    • Added three extra on-die temperature sensors to RV770 monitoring
    • Removed states.dmp file creation
    • Fixed GPU activity readings on RV770
    • Changed devices list order to be more intuitive (by bus number now)
    • Added Shared Memory support, see the forum for more info
    • Fixed more 190°C PCB readings on NVIDIA
    • Catalyst Beta versions no longer displayed as version 2.2
    • Fixed sensor graph overflow
    • Sensor graphs will try to autoscale now
    • Fixed RV505 process size
    • Fixed memory bus width reading on some ATI RS300
    • Fixed rare crash when reading NVIDIA sensors
    • Fixed GDDR3 detection for G71
    download diretto
  9. #29
    • Added full support for HD 4870 X2
    • Added support for reading clocks on newer ATI drivers (R700)
    • Fix for realtime clock sensor showing double memory speed on RV770 GDDR5
    • Added detection for GeForce 9800 GT, GeForce 9300 GE
    • Added support to start GPU-Z minimized (use -minimized)
    • Added tray icon when GPU-Z is minimized
    • Fixed crash when uploading large BIOS files
    • Fixed rare crash that could happen on some NVIDIA cards
    • Added detection for Intel Q43. G45 and some variants of G35, G965, GM965
    download diretto
  10. #30
    upgrade per gpu_z
    0.2.7
    • Added display for GPU release date. The data is incomplete, if you have more info please post in the sticky thread in the support forums.
    • Added display for transistor count
    • Added mouseover readings for sensors graph
    • Correctly named the three on-die sensors of RV770 and RV730
    • Added support for voltage regulator monitoring on HD 4870 and HD 4870 X2
    • RV770 GPU on HD 4870 X2 now called R700
    • Added support for reading HD 4870 X2 3D clocks
    • Added display of CrossFire Sideport status on HD 4870 X2
    • Added more RV730 device IDs
    • Added support for GeForce 9800 GT, 9800M GT, 9600M GT, 9700M GS/GT, 9500M G
    • Added detection for RS780D
    • Fixed incorrectly read ATI OD5 clocks
    • Fix for memory clock reading on RV730
    • Fixed ROM reading on RV730
    • Fixed crash when no supported card detected
    • Sensor graph width adjusted when scrollbars visible
    download diretto
Pagina 3 di 10
  1. Guida: ATI GPU + NVIDIA GPU (for physx)
    By Caos85 in forum -= Schede video e acceleratori =-
    Risposte: 153
  2. Temperatura gpu e diodo gpu
    By PANDAROSSO in forum -= Overclocking e CPU =-
  3. TechPowerUp Radeon Bios Editor v1.15
    By brugola.x in forum AMD: drivers , utility and tweaking
