ho scaricato ora anke l'ultimo manuale dal sito ecs ma non dice nulla a proposito di jumper.......devo sostituire la batt.????
Ho apura che il bios per overclock non gradisca molto l'athlon xp
Che versione è il bios che hai scaricato????
Ho messo questo...non va bene????...dice che supporta il 2400!?!??!?!?!? :O(
CheepoBios 1.05 beta for K7S5A
Based on ECS 020809 beta
chb0809.rom non-lan Version
chb0809l.rom lan version
chb0809f.rom lan version with fastwrites enabled (disable lan in bios Setup to use it on a non-lan board)
Release notes:
- Support for AMD 2400+ and 2600+ Thoroughbred CPU (it was ECS who added this, not me!)
- Adjust timing for stability and compatibility
- FSB modes reprogrammed:
"100/100 MHz" changed from 99.6 to 100.9 MHz
"133/133 MHz" changed from 132.77 to 133.9 MHz
No more underclocking by default!
- Several FSB modes added. New list of available modes:
100/100 MHz
100/133 MHz
133/133 MHz -> Default modes
66/66 MHz (H/W Trap)
112/112 MHz
124/124 MHz
138/138 MHz (reprogrammed from 137.3 to 138.0)
150/150 MHz
166/166 MHz -> Already present in the "OC" bios
110/110 MHz
133/100 MHz
143/143 MHz
147/147 MHz
133/166 MHz
160/120 MHz
200/200 MHz
Please note that the "166 MHz no-boot issue" hasn't been dealt with
in this bios modification. It seems that bios timings need to be adjusted to allow
booting at such speed. This issue could also affect 160/120 and 200/200
settings.
- Extra memory settings:
- RAS Precharge Time=2T
- RAS Active Time=4T, 5T
- Full screen logo can be enabled/disabled via bios menu
- A few hidden bios options have been enabled with amibcp. Please notice that none of these settings have been fixed or reprogrammed at all.
- PCI Latency Timer
- PCI slot #1 to #4 IRQ priority
- IO APIC
Note: there is no need to enable PCI IDE Busmaster anymore, it was already present as an available option in the ecs beta
The default values for these settings, as well as all other settings, remain the same as in the original bios.
I wish to thank Jinxter, tw.p, Bench400 and Beheerder: deblokker mij, fellow bios modders
at www.ocworkbench.com/ecs for their useful ideas, discussion and testing
Cheepoman 22 August 2002
non ho detto ke li avevo ho detto di fare attenzione a ke nn ci fossero!Originally posted by opendore
ho scaricato ora anke l'ultimo manuale dal sito ecs ma non dice nulla a proposito di jumper.......devo sostituire la batt.????![]()
hai provato con 138/138?
curiosità...perchè a 138 dovrebbe funzionare e a 133 no????
una volta su una mobo dopo aver flashato il bios nn fungeva + a 133 ma solo a 134-135-136 etc etc
Prova a flashare di nuovo altrimenti!
Anzi prima leggi un pò per bene i vari thread del forum di Ocworkbenchche magari ne parlano!![]()
ok...domani provo...x ora grazie...ci sentiamo domani!!!
Non chiedetemi xcè...ho cambiato cpu....ho 2 xp 1800+ e con l'altro funzia!!!!!!! booooooooooooo.........non riesc proprio a capire.......l'altro funge a 100 mhz.......e lo vede a 1200 appena metto a 133 il buio + buio!!!!!!
