Pagina 180 di 184
... 80 130 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 ultimo
Visualizzazione dei risultati da 1,791 a 1,800 su 1835
  1. #1791
    Moderatore L'avatar di bibo01
    Oct 2010
    È uscito Network Audio Daemon 4.3.0 !
    Improvements to the input support, especially on slaved source clocks.
  2. #1792
    Oct 2010
    È uscito HQPlayer 4 Desktop 4.21.0!
    Added delay plugin to matrix processor. Improvements to volume spinner in Client. CUDA 12 support with improved support for Lovelace and Hopper. CUDA support enabled on Fedora 36 build. Workaround for macOS Ventura on Intel silicon USB audio problem. Component updates. Small fixes and improvements.
    …insieme all’aggiornamento 4.21.0 di HQP Desktop è uscito anche l’aggiornamento del Client con queste novità :
    New Client is now out. Note that this uses standard mouse wheel settings for the volume, instead of my custom mouse wheel code in earlier version. So to adjust sensitivity, you can go to Windows mouse settings to adjust how many “lines” it scrolls at a time. This also depends on the mouse model in question.
    Ultima modifica di bibo01 : 22-12-2022 a 13:07
  3. #1793
    Oct 2010
    È uscito HQPlayer embedded 4.34.0 !
    Added delay plugin to matrix. Component updates including CUDA 12 support, also on Fedora. Small fixes and improvements.
  4. #1794
    Oct 2010
    È uscito HQPlayer 4 Desktop 4.21.1!
    Small fixes and improvements. Component updates.
  5. #1795
    Oct 2010
    È uscito HQPlayer 4 Embedded 4.34.1!
    Small fixes and improvements. Component updates. Note! Port number of web interface on HQPlayer OS is now same as elswhere - 8088!
  6. #1796
    kibibyte L'avatar di giordy60
    Dec 2010
    prov. cremona
    è disponibile HQPlayer 4 embedded release 4.34.2
    ed anche il NAD 4.4.0
    Mar 19 2023 HQPlayer 4 Embedded 4.34.2 released.
    Minor fixes. Component updates.
    Mar 19 2023 Network Audio Daemon 4.4.0 released!
    Minor performance optimizations. NAA OS update.
    il sistema audio
    Server HDPlex (i7-6700-WS2016) HQPlayer in Ramdisk + HQPDcontrol> Macmini (roon core + Tidal e qobuz ) ma anche hqplayer client con qobuz installato su portatile> HDPlex NAA (celeron G1840T-WS2016) NAD in Ramdisk, ma anche miniPC fitlet con immagine x86 per NAA > switch rete tp-link, Denafrips Ares2, SPLvolume2, monitor klein+hummel o410+sub Neumann KHo810
  7. #1797
    Dec 2010
    prov. cremona
    è uscito HQPlayer Embedded 4.35.0
    Apr 17 2023 HQPlayer 4 Embedded 4.35.0 released!
    Performance improvements, especially for cases when huge filters or convolution is run on CPU. Component updates and minor fixes.
    anche la versione desktop è stata aggiornata alla release 4.22.0
    Apr 18 2023 HQPlayer 4 Desktop 4.22.0 released!
    Performance improvements, especially for cases when huge filters or convolution is run on CPU. Option to control playlist elide side on Client. Fixed CD playback on macOS. Minimum required OS version on Intel Macs is 10.15. Component updates and minor fixes.
    Ultima modifica di giordy60 : 18-04-2023 a 13:04
    il sistema audio
  8. #1798
    Dec 2010
    prov. cremona
    May 5 2023
    30 years since the first DAC design, 25 years since the beginning of the HQPlayer project, and 15 years since first commercial release of HQPlayer, it is time to release fifth generation of HQPlayer technology. Perfecting listening expriences by harnessing power of modern DSP. As result of endless research & development of better algorithms powered by modern DSP computing capabilities.
    Jussi ha rilasciato le release 5 di HQPlayer sia desktop che embedded
    May 5 2023 HQPlayer 5 Desktop 5.0.0 released!
    Several new filters and modulators, extended source content analysis and output metering, new CUDA offload capabilities, metring display in Client, GUI improvements, RaspberryPi4 supported as a new platform.
    May 5 2023 HQPlayer 5 Embedded 5.0.0 released!
    Several new filters and modulators, extended source content analysis and output metering, new CUDA offload capabilities.
    May 5 2023 HQPlayer 4 series enters two year maintenance mode period.
    il sistema audio
  9. #1799
    nibble
    Feb 2016
    Salve a tutti,
    ho installato HQPlayer4 Desktop 4.13.1 (il mio pc non supporta le versioni Windows successive) su Windows 10 Pro, su pc con processore Intel i3 con 12gb di ram. Ascolto con Chord Mojo dac e Cubox i2ex su cui ho installato Debian Bullseye e Network Audio Daemon 4.4.0. Il Cubox ha una connessione diretta al PC.
    Sullo stesso pc c'è Ubuntu 22.04.2 LTS in dual-boot su cui ho installato HQPlayer4 Desktop 4.22.0. Su Windows, HQP vede il Cubox, mentre su Ubuntu no. Chiedo se per favore mi sapete indicare una soluzione.
    Di seguito alcune interrogazioni, che magari possono essere utili, effettuate sul Cubox e su Ubuntu:
    sul Cubox
    debian@sr-imx6:~$ sudo ifconfig
    [sudo] password for debian:
    eth0: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC> mtu 1500
    inet 192.168.1.233 netmask 255.255.255.0 broadcast 192.168.1.255
    inet6 fe80::d263:b4ff:fe00:a37d prefixlen 64 scopeid 0x20<link>
    ether d0:63:b4:00:a3:7d txqueuelen 1000 (Ethernet)
    RX packets 11908 bytes 1096760 (1.0 MiB)
    RX errors 0 dropped 5070 overruns 0 frame 0
    TX packets 1481 bytes 120623 (117.7 KiB)
    TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
    lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
    inet 127.0.0.1 netmask 255.0.0.0
    inet6 ::1 prefixlen 128 scopeid 0x10<host>
    loop txqueuelen 1 (Local Loopback)
    RX packets 92 bytes 7861 (7.6 KiB)
    RX errors 0 dropped 0 overruns 0 frame 0
    TX packets 92 bytes 7861 (7.6 KiB)
    debian@sr-imx6:~$ sudo route
    Kernel IP routing table
    Destination Gateway Genmask Flags Metric Ref Use Iface
    default modemtim.homene 0.0.0.0 UG 0 0 0 eth0
    192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
    modemtim.homene 0.0.0.0 255.255.255.255 UH 0 0 0 eth0
    debian@sr-imx6:~$ sudo nano /etc/network/interfaces
    # interfaces(5) file used by ifup(8) and ifdown(8)
    # Include files from /etc/network/interfaces.d:
    source-directory /etc/network/interfaces.d
    # The loopback network interface
    auto lo
    iface lo inet loopback
    # The primary network interface
    auto eth0
    iface eth0 inet static
    address 192.168.1.10
    gateway 192.168.1.1
    su Ubuntu
    vincenzo@vincenzo-imedia-S3850:~$ ifconfig
    eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
    inet 192.168.1.130 netmask 255.255.255.0 broadcast 192.168.1.255
    ether 10:78:d2:c4:79:f5 txqueuelen 1000 (Ethernet)
    RX packets 5336 bytes 4753739 (4.7 MB)
    RX errors 0 dropped 129 overruns 0 frame 0
    TX packets 3319 bytes 567520 (567.5 KB)
    device interrupt 20 memory 0xfb100000-fb120000
    loop txqueuelen 1000 (Loopback locale)
    RX packets 918 bytes 151929 (151.9 KB)
    TX packets 918 bytes 151929 (151.9 KB)
    vincenzo@vincenzo-imedia-S3850:~$ route
    Tabella di routing IP del kernel
    Destinazione Gateway Genmask Flag Metric Ref Usa Iface
    default modemtim.homene 0.0.0.0 UG 100 0 0 eno1
    link-local 0.0.0.0 255.255.0.0 U 1000 0 0 eno1
    192.168.1.0 0.0.0.0 255.255.255.0 U 100 0 0 eno1
    vincenzo@vincenzo-imedia-S3850:~$ sudo nano /etc/network/interfaces
    [sudo] password di vincenzo:
    auto lo
    Cordiali saluti.
    Vincenzo
  10. #1800
    nibble
    Feb 2016
    Originariamente inviato da francy2007
    Salve a tutti,
    sul Cubox
    auto lo
    auto eth0
    gateway 192.168.1.1
    su Ubuntu
    auto lo
    Cordiali saluti.
    Vincenzo
    Faccio seguito al post precedente. Ho visto sulla discussione "Che si fa? Sistema HQPlayer e NAA" dei vecchi post di UnixMan riguardanti le configurazioni di rete per collegare un NAA a HQPlayer (pag. 129) ed ho constatato che è molto padrone dell'argomento. Chiedo, quindi, se possibile, un suo aiuto. Ovviamente è gradito l'aiuto di chiunque altro.
    Saluti.
    Vincenzo
Pagina 180 di 184
