-= Lista Software Freeware =-
Pagina 17 di 26
... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 ultimo
Visualizzazione dei risultati da 161 a 170 su 258
  1. #161
    Oct 2004
    Versione 2.0.0.4 per Firefox.
    Release Notes:
    http://www.mozilla.com/en-US/firefox.../releasenotes/
    Link per il download:
    http://www.mozilla.com/en-US/firefox/all.html
  2. #162
    aggiornato izarc alla v3.8b1510
    http://www.atris.it/Forum/showpost.p...4&postcount=39
    storico:
    -Fixed: Shell context menu under Windows Vista (Now IZArc is 100% Vista (32-bit) compatible)
    -Fixed: Confirm File Overwrites when extracting *.tar.gz archives
    -Fixed: Compress folders with file names beginning with dot (.test)
    -Fixed: Shortcuts working directory when do CheckOut
    -Fixed: Modify and update files in subfolders
    -Fixed: Drag and Drop folder from an archive to Windows Explorer does not extract subfolders
    -Fixed: Extraction process is terminated if some error occurs
    -Fixed: Extract multi-volume ARJ archives
    -Fixed: Check for update
    -Fixed: Zip SFX archive crashes when is unable extracting directory to be created
    -Added option to compress/extract archives in background (low process priority)
    -Added 7-Zip SFX creation support
    -Updated UnRar library
    -Some small improvements
    -Updated translations
  4. #164
    aggiornato jkdefrag alla v3.14.
    http://www.atris.it/Forum/showpost.p...59&postcount=4
    Changes:
    - Bugfix for the "-u" commandline option. All the "-u" masks were accidentally
    also processed as "items".
    - Files are now classed as a SpaceHog when their last access time is more than
    30 days ago.
    - Deleted the "full" optimization ("-a 4"). For backward compatibility the
    program still accepts the option, but does exactly the same as for "-a 3".
    - The screensaver will now not start if it detects that the computer is running
    on battery power.
    - Deleted the code that disables the Windows display idle timer (screen saver) and
    system idle timer (power saver) in the commandline and screensaver versions.
    For programmers:
    - Deleted message 57 from the message array.
    - Changed the meaning of the "Data->Phase" variable used by the ShowStatus()
    callback.
    - The ShowStatus() callback is now executed once for every zone in the "-a 3"
    and "-a 7"..."-a 11" optimizations.
  5. #165
    aggiornata la versione portable di firefox .
    http://www.atris.it/Forum/showpost.p...8&postcount=27
  6. #166
    aggiornato jkdefrag alla v3.15
    Changes:
    - Added extra breakpoints so the program will quit faster.
    - Added special exception for Acronis OS Selector files.
    - Changes to facilitate Delphi programmers. All callbacks are now CDECL.
    - Added a Pascal example program.
  7. #167
    aggiornato undelete plus alla v2.9
    http://www.atris.it/Forum/showpost.p...3&postcount=14
    changes:
    - Windows Vista support added
    - Hide overwritten and hide temparary files filter option added
    - multilanguage support updated
    - small interface improvements
    - small bugs fixed
  8. #168
    aggiornato izarc alla v3.81
    changes:
    -Fixed: Zip files and folders with non English names
    -Fixed: Split/Merge Zip archives containing non English filenames
    -Fixed: Extract CAB SFX archives
    -Fixed: Show the amount of extracted files from TGZ archives.
  9. #169
    gibibyte L'avatar di Konrad76
    Mar 2007
    Bergamo city
    Mi iscrivo......veramente uno spettacolo....complimenti....
Pagina 17 di 26
  1. Giochi Freeware in generale.
    By CALMA INSOLITA in forum -= Pc: giochi, novità e giochi on-line! =-
    Risposte: 119
  2. Software freeware per immagini vettoriali
    By salvatore in forum -= Sistemi Operativi Windows e software generale =-
  3. Lista antrivirus freeware, Antivirus Online, Antispyware, Tools di rimozione
    By parsifal in forum -= Sistemi Operativi Windows e software generale =-
  4. Opera diventa freeware
    By AirJ in forum -= Sistemi Operativi Windows e software generale =-
  5. Siti Freeware
    By pchardware in forum -= La Piazza =-
