DSD in LMS con SOX
Pagina 14 di 115
... 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 64 114 ... ultimo
Visualizzazione dei risultati da 131 a 140 su 1145
  1. #131
    tebibyte L'avatar di UnixMan
    Sep 2013
    Niente da fare: senza "-D" converte in PCM, con "-D" va in DoP:
    codice:
    *** /tmp/squeezelite.log ***
    [21:12:10.290749] decode_flush:190 decode flush
    [21:12:10.290790] output_flush:423 flush output buffer
    [21:12:10.362110] codec_open:218 codec open: 'd'
    [21:12:10.362175] stream_sock:384 connecting to 127.0.0.1:9000
    [21:12:10.362238] stream_sock:413 header: GET /stream.mp3?player=00:1c:c0:37:22:73 HTTP/1.0
    [21:12:10.383171] stream_thread:176 headers: len: 115
    HTTP/1.1 200 OK
    Server: Logitech Media Server (7.9.0 - 1468928517)
    Connection: close
    Content-Type: audio/dsf
    [21:12:10.443517] output_thread:690 open output device: hw:CARD=D20
    [21:12:10.443983] alsa_open:366 opening device at: 44100
    [21:12:10.444255] alsa_open:435 opened device hw:CARD=D20 using format: S32_LE sample rate: 44100 mmap: 1
    [21:12:10.444299] alsa_open:526 buffer: 499 period: 3 -> buffer size: 22005 period size: 7335
    [21:12:10.565136] _read_header:158 DSF version: 1 format: 0
    [21:12:10.565293] _read_header:168 channels: 2
    [21:12:10.565301] _read_header:169 sample rate: 5644800
    [21:12:10.565307] _read_header:170 lsb first: 1
    [21:12:10.565314] _read_header:171 sample bytes: 186720576
    [21:12:10.565320] _read_header:172 block size: 4096
    [21:12:10.565327] _read_header:178 found dsd len: 373448716
    [21:12:10.565334] dsd_decode:735 setting track_start
    [21:12:10.565340] dsd_decode:780 DSD128 stream, format: DOP, rate: 352800Hz
    [21:12:10.735239] _output_frames:61 start buffer frames: 13103104
    [21:12:10.735305] _output_frames:146 track start sample rate: 352800 replay_gain: 0
    [21:12:10.745327] output_thread:690 open output device: hw:CARD=D20
    [21:12:10.760401] alsa_open:366 opening device at: 352800
    [21:12:10.760662] alsa_open:435 opened device hw:CARD=D20 using format: S32_LE sample rate: 352800 mmap: 1
    [21:12:10.760693] alsa_open:526 buffer: 499 period: 3 -> buffer size: 131070 period size: 43690
    *** /var/log/squeezeboxserver//server.log ***
    [17-02-06 21:12:13.7016] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: dsf->dsf via: -
    In quel branch le patch di Daphile sono già applicate / vengono applicate automaticamente o bisogna applicarle a mano??
    Ciao, Paolo.
  2. #132
    Aug 2011
    occhio a tirare giù il branch giusto: se dai solo "git clone", senza opzioni, ti tira giù il master. Verifica che sia presente la subdir "Daphile patches"...
    quel'é l'indirizzo giusto?
  3. #133
    Sep 2013
    Bingo!
    per andare in DSD nativo è necessario specificare -D seguito dal formato nativo utilizzato dalla propria scheda (nel mio caso 'u32be'):
    codice:
    nice --20 squeezelite -n 'R2@spmc' -C 1 -D :u32be -o 'hw:CARD=D20' -V 'DIYINHK USB Audio 2.0 ' -s 127.0.0.1 -m '00:1c:c0:37:22:73' -b '102400:102400' -a '499:3' -p 89 -d 'all=info' -d 'slimproto=warn'
    codice:
    [21:21:30.689532] stream_init:290 init stream
    [21:21:30.763477] output_init_alsa:876 init output
    [21:21:30.763565] output_init_alsa:916 device : hw:CARD=D20 requested alsa_buffer: 499 alsa_period: 3 format: any mmap: 1
    [21:21:30.765046] output_init_common:410 supported rates: 768000 705600 384000 352800 192000 176400 96000 88200 48000 44100
    [21:21:30.843664] output_init_alsa:932 memory locked
    [21:21:30.845015] decode_init:129 init decode, include codecs:  exclude codecs:
    [21:21:30.845074] register_dsd:867 using dsd to decode dsf,dff
    [21:21:30.845303] load_faad:610 loaded libfaad.so.2
    [21:21:30.845313] register_faad:640 using faad to decode aac
    [21:21:30.845629] load_vorbis:300 loaded libvorbisfile.so.3
    [21:21:30.845639] register_vorbis:329 using vorbis to decode ogg
    [21:21:30.845866] load_flac:263 loaded libFLAC.so.8
    [21:21:30.845875] register_flac:291 using flac to decode flc
    [21:21:30.845883] register_pcm:419 using pcm to decode aif,pcm
    [21:21:30.846026] load_mad:383 loaded libmad.so.0
    [21:21:30.846035] register_mad:412 using mad to decode mp3
    [21:21:30.881442] codec_open:218 codec open: 'd'
    [21:21:30.881506] stream_sock:384 connecting to 127.0.0.1:9000
    [21:21:30.881561] stream_sock:413 header: GET /stream.mp3?player=00:1c:c0:37:22:73 HTTP/1.0
    [21:21:30.965610] stream_thread:176 headers: len: 115
    HTTP/1.1 200 OK
    Connection: close
    [21:21:31.045102] output_thread:690 open output device: hw:CARD=D20
    [21:21:31.045588] alsa_open:366 opening device at: 44100
    [21:21:31.045824] alsa_open:435 opened device hw:CARD=D20 using format: S32_LE sample rate: 44100 mmap: 1
    [21:21:31.045858] alsa_open:526 buffer: 499 period: 3 -> buffer size: 22005 period size: 7335
    [21:21:31.046785] _read_header:158 DSF version: 1 format: 0
    [21:21:31.046932] _read_header:168 channels: 2
    [21:21:31.046938] _read_header:169 sample rate: 5644800
    [21:21:31.046943] _read_header:170 lsb first: 1
    [21:21:31.046947] _read_header:171 sample bytes: 186720576
    [21:21:31.046951] _read_header:172 block size: 4096
    [21:21:31.046955] _read_header:178 found dsd len: 373448716
    [21:21:31.046960] dsd_decode:735 setting track_start
    [21:21:31.046966] dsd_decode:780 DSD128 stream, format: DSD_U32_BE, rate: 176400Hz
    [21:21:31.217037] _output_frames:61 start buffer frames: 6990848
    [21:21:31.217098] _output_frames:146 track start sample rate: 176400 replay_gain: 0
    [21:21:31.227129] output_thread:690 open output device: hw:CARD=D20
    [21:21:31.240445] alsa_open:366 opening device at: 176400
    [21:21:31.240684] alsa_open:435 opened device hw:CARD=D20 using format: DSD_U32_BE sample rate: 176400 mmap: 1
    [21:21:31.240712] alsa_open:526 buffer: 499 period: 3 -> buffer size: 88023 period size: 29341
    Ciao, Paolo.
  4. #134
    Sep 2013
    l'indirizzo è sempre lo stesso, devi aggiungere l'opzione per scegliere il branch. In alternativa, scarica lo zip.
    Ciao, Paolo.
  5. #135
    Sep 2013
    Ci siamo quasi!!!
    Per curiosità ho provato a rimettere la versione di sox con le patch di Daphile e, ...
    LMS:
    codice:
    [17-02-06 21:34:20.3389] Slim::Player::StreamingController::play (2100) 00:1c:c0:37:22:73
    [17-02-06 21:34:20.3394] Slim::Player::StreamingController::_Stop (603) Song queue is now 0
    [17-02-06 21:34:20.3397] Slim::Player::StreamingController::_setPlayingState (2357) new playing state STOPPED
    [17-02-06 21:34:20.3399] Slim::Player::StreamingController::_setStreamingState (2366) new streaming state IDLE
    [17-02-06 21:34:20.3407] Slim::Player::Song::new (108) index 0 -> file:///music/file.flac
    [17-02-06 21:34:20.3410] Slim::Player::StreamingController::_setStreamingState (2366) new streaming state TRACKWAIT
    [17-02-06 21:34:20.3422] Slim::Player::StreamingController::_playersMessage (789) Now Playing: file:///music/file.flac
    [17-02-06 21:34:20.3436] Slim::Player::Song::getNextSong (229) file:///music/file.flac
    [17-02-06 21:34:20.3438] Slim::Player::StreamingController::_nextTrackReady (737) 00:1c:c0:37:22:73: nextTrack will be index 0
    [17-02-06 21:34:20.3440] Slim::Player::StreamingController::_Stream (1203) Song queue is now 0
    [17-02-06 21:34:20.3446] Slim::Player::StreamingController::_Stream (1206) 00:1c:c0:37:22:73: preparing to stream song index 0
    [17-02-06 21:34:20.3449] Slim::Player::Song::open (363) file:///music/file.flac
    [17-02-06 21:34:20.3459] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [sox] -q  -t flac $FILE$ -t dsf  -b 1 - rate -vMn 5644800 sdm -f  sdm-8
    [17-02-06 21:34:20.3467] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [sox] -q  -t flac $FILE$ -t dsf  -b 1 - rate -vMn 5644800 sdm -f  sdm-8
    [17-02-06 21:34:20.3469] Slim::Player::Song::open (387) seek=false time=0 canSeek=2
    [17-02-06 21:34:20.3477] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [sox] -q  -t flac $FILE$ -t dsf  -b 1 - rate -vMn 5644800 sdm -f  sdm-8
    [17-02-06 21:34:20.3480] Slim::Player::Song::open (408) Transcoder: streamMode=F, streamformat=dsf
    [17-02-06 21:34:20.3482] Slim::Player::Song::open (547) isRemote? No
    [17-02-06 21:34:20.3484] Slim::Player::Song::open (548) is sock defined? No
    [17-02-06 21:34:20.3486] Slim::Player::Song::open (552) usepipe? No
    [17-02-06 21:34:20.3491] Slim::Player::TranscodingHelper::tokenizeConvertCommand2 (617) Using command for conversion: "/usr/share/squeezeboxserver/Bin/x86_64-linux/sox" -q  -t flac "/music/file.flac" -t dsf  -b 1 - rate -vMn 5644800 sdm -f  sdm-8 & |
    [17-02-06 21:34:20.3493] Slim::Player::Song::open (563) Tokenized command: "/music/file.flac" -t dsf  -b 1 - rate -vMn 5644800 sdm -f  sdm-8 & |
    [17-02-06 21:34:20.6553] Slim::Player::StreamingController::_Stream (1265) 00:1c:c0:37:22:73: stream
    [17-02-06 21:34:20.6578] Slim::Player::StreamingController::_Stream (1302) Song queue is now 0
    [17-02-06 21:34:20.6581] Slim::Player::StreamingController::_setPlayingState (2357) new playing state BUFFERING
    [17-02-06 21:34:20.6583] Slim::Player::StreamingController::_setStreamingState (2366) new streaming state STREAMING
    [17-02-06 21:34:20.6936] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [sox] -q  -t flac $FILE$ -t dsf  -b 1 - rate -vMn 5644800 sdm -f  sdm-8
    [17-02-06 21:34:20.6946] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [sox] -q  -t flac $FILE$ -t dsf  -b 1 - rate -vMn 5644800 sdm -f  sdm-8
    [17-02-06 21:34:21.6069] Slim::Player::StreamingController::playerTrackStarted (2180) 00:1c:c0:37:22:73
    [17-02-06 21:34:21.6071] Slim::Player::StreamingController::_setPlayingState (2357) new playing state PLAYING
    [17-02-06 21:34:21.6073] Slim::Player::StreamingController::_Playing (361) Song 0 has now started playing
    [17-02-06 21:34:21.6079] Slim::Player::StreamingController::_Playing (390) Song queue is now 0
    [17-02-06 21:34:22.6386] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [sox] -q  -t flac $FILE$ -t dsf  -b 1 - rate -vMn 5644800 sdm -f  sdm-8
    [17-02-06 21:34:22.6392] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [sox] -q  -t flac $FILE$ -t dsf  -b 1 - rate -vMn 5644800 sdm -f  sdm-8
    [17-02-06 21:34:23.6143] Slim::Player::StreamingController::pause (2116) 00:1c:c0:37:22:73
    [17-02-06 21:34:23.6151] Slim::Player::StreamingController::_setPlayingState (2357) new playing state PAUSED
    [17-02-06 21:34:23.6166] Slim::Player::Source::playmode (96) 00:1c:c0:37:22:73: Current playmode: pause
    squeezelite log:
    codice:
    [21:34:20.344225] decode_flush:190 decode flush
    [21:34:20.344270] output_flush:423 flush output buffer
    [21:34:20.657444] codec_open:218 codec open: 'd'
    [21:34:20.657501] stream_sock:384 connecting to 127.0.0.1:9000
    [21:34:20.657563] stream_sock:413 header: GET /stream.mp3?player=00:1c:c0:37:22:73 HTTP/1.0
    [21:34:20.739332] stream_thread:176 headers: len: 115
    HTTP/1.1 200 OK
    Connection: close
    [21:34:20.936302] output_thread:690 open output device: hw:CARD=D20
    [21:34:20.936374] alsa_open:366 opening device at: 176400
    [21:34:20.936669] alsa_open:435 opened device hw:CARD=D20 using format: DSD_U32_BE sample rate: 176400 mmap: 1
    [21:34:20.936698] alsa_open:526 buffer: 499 period: 3 -> buffer size: 88023 period size: 29341
    [21:34:20.947633] _read_header:158 DSF version: 1 format: 0
    [21:34:20.947709] _read_header:168 channels: 2
    [21:34:20.947715] _read_header:169 sample rate: 5644800
    [21:34:20.947719] _read_header:170 lsb first: 1
    [21:34:20.947724] _read_header:171 sample bytes: 2305843009213693951
    [21:34:20.947728] _read_header:172 block size: 4096
    [21:34:20.947732] _read_header:178 found dsd len: 12
    [21:34:20.947737] dsd_decode:735 setting track_start
    [21:34:20.947741] dsd_decode:780 DSD128 stream, format: DSD_U32_BE, rate: 176400Hz
    [21:34:21.606346] _output_frames:61 start buffer frames: 188416
    [21:34:21.606399] _output_frames:146 track start sample rate: 176400 replay_gain: 0
    [21:34:24.766603] output_thread:803 disabling output
    esce un sacco di rumore (e pure DC), poi va in protezione l'ampli... ma, per un attimo, in mezzo al rumore qualcosa si sente!
    Se si riesce a sistemare il problema con sox, forse funziona...
    Ciao, Paolo.
  6. #136
    Jan 2013
    Ci siamo quasi!!!
    LMS:
    codice:
    squeezelite log:
    codice:
    HTTP/1.1 200 OK
    Connection: close
    Questo è quello che volevo sentire...
    a. il 'blocco' è risolto dalla patch da Sox, che va corretta e sistemata, ma per la parte relativa al size è OK (togli qualsiasi modifica tu abbia fatto a write_bits)
    b. abbiamo (sembra) svelato l'arcano del DSD nativo, poi qualcuno mi spiega cosa sono quei formati... ma dsd non è bitstream? Ed in pa?
    c. riscarica e ricompila, ho applicato le ulteriori patch, vediamo se risolvono il problema di allineamento.
    NOTA BENE: BIG ENDIAN???
    Se davvero l'uscita verso USB deve essere in formato big endian, significa che squeezelite si deve passare byte per byte ed invertire l'ordine dei bit... assolutamente inefficiente, che non valgala pena inviare big endian già da sox.
    Ultima modifica di marcoc1712 : 06-02-2017 a 22:40
    Ciao, Marco.
  7. #137
    Sep 2013
    FERMI TUTTI: BINGO!
    ho provato ad applicare soltanto il primo hunk della patch Daphile per sox, questo:
    codice:
    diff --git a/src/dsf.c b/src/dsf.c
    index 2f17c8d..3b68364 100644
    --- a/src/dsf.c
    +++ b/src/dsf.c
    @@ -221,7 +221,7 @@ static int dsf_writeheader(sox_format_t *ft)
                lsx_writedw(ft, dsf->chan_num) ||
                lsx_writedw(ft, dsf->sfreq) ||
                lsx_writedw(ft, dsf->bps) ||
    -           lsx_writeqw(ft, dsf->scount) ||
    +           lsx_writeqw(ft, dsf->scount ? dsf->scount : UINT64_MAX) ||
                lsx_writedw(ft, dsf->block_size) ||
                lsx_writedw(ft, 0) || /* reserved */
                lsx_writedw(ft, DATA_TAG) ||
    e...
    ;2 FUNZIONA, SUONA!!!!!!!!!!! ;1
    Ciao, Paolo.
  8. #138
    Jan 2013
    Vediamo di fare il punto:
    a. SOX va patchato, ma la patch di Daphile non è coerente con la versione in corso, quindi bisogna 'coreggere' manualmente (v. sotto) e ricompilare.
    b. Squeezelite-R2 va corretto applicando le patch di Daphile in merito al play back di DSD nativo ed altro (fatto, v. 1.8.5).
    Una volta fatto, le righe:
    wav dsf * *
    # FT:{START=--skip=%t}U:{END=--until=%v}
    [flac] -cs --totally-silent --compression-level-0 $START$ $END$ -- $FILE$ | [sox] -q -t flac - -t dsf -b 1 - rate -vMn 2822400 sdm -f sdm-8
    e
    flac dsf * *
    [flac] -dcs --totally-silent $START$ $END$ -- $FILE$ | [sox] -q -t wav- -t dsf -b 1 - rate -vMn 2822400 sdm -f sdm-8
    funzionano come ci si aspetta (@Paolo prego confermare o correggere)?
    Rimane da verificare l'allinamento dei diversi formati in modo da otteere musica e non rumore...
    NOTA SU SOX:
    La patch da applicare è SOLO questa:
    codice:
    --- a/src/dsf.c
    +++ b/src/dsf.c
    @@ -259,7 +259,10 @@ static int dsf_write_buf(sox_format_t *ft)
     		if (lsx_write_b_buf(ft, dsf->block, wlen) < wlen)
     			return SOX_EOF;
     		dsf->block_pos = 0;
    -		memset(dsf->block, 0, wlen);
    +		if (ft->seekable)
    +			memset(dsf->block, 0, wlen);
    +		else
    +			memset(dsf->block, 0x69, wlen);
     	return SOX_SUCCESS;
    Ciao, Marco.
  9. #139
    Jan 2013
    FERMI TUTTI: BINGO!
    codice:
    --- a/src/dsf.c
    +++ b/src/dsf.c
    e...
    come volevasi dimostrare...
    Puoi applicare anche il secondo e dovrebbe funzionare ugualmente ma gestendo il doppio caso, il resto dimenticalo. Se me lo confermi, invio la patch con richiesta di integrazione a Mansr, così fa prima (a meno che non voglia farlo tu).
    Hai ricompilato squeezelite o sei sempre alla versione precedente? solo per sapere se le altre patch sono necessarie o solo eventualmente utili.
    V. ultimo post," facciamo il punto", così aiutiamo tutti a mettersi nelle stesse condizioni e partiamo di li per i prossimi passi.
    Bel risultato.
    Ciao, Marco.
  10. #140
    Sep 2013
    sì, esatto.
    N.B.: non ho ancora provato l'ultima versione aggiornata che hai postato poco fa, sta funzionando con quella precedente (quella dell'altro giorno, la prima che hai messo online con le patch di Daphile).
    ehm... ci hai infilato vari errori. Queste funzionano perfettamente:
    codice:
    #wav dsf * *
    #       # FT
    #       [sox] -q  -t wav $FILE$ -t dsf  -b 1 - gain -h rate -vMn 5644800 sdm -f sdm-8
    #flc dsf * *
    #       # FT
    #       [sox] -q  -t flac $FILE$ -t dsf  -b 1 - gain -h rate -vMn 5644800 sdm -f  sdm-8
    wav dsf * *
            [flac] -cs --totally-silent --compression-level-0 $START$ $END$ -- $FILE$ | [sox] -q -t flac - -t dsf  -b 1 - gain -h rate -vMn 5644800 sdm -f sdm-8
    flc dsf * *
            [flac] -dcs --totally-silent $START$ $END$ -- $FILE$ | [sox] -q  -t wav - -t dsf  -b 1 - gain -h rate -vMn 5644800 sdm -f  sdm-8
    sia quelle commentate, solo con sox (che non permettono di "saltare" all'interno del brano) che quelle con flac+sox (che invece lo permettono).
    io adesso sto già ottenendo musica! Sembra funzionare perfettamente. Niente più rumore, salvo un fastidioso "click" al cambio traccia.
    NOTA SU SOX:
    NO! Altrimenti ottieni il "quasi funzionamento" del mio tentativo precedente (che prevedeva proprio quello).
    Si deve applicare soltanto il PRIMO "hunk", questo:
    codice:
    --- a/src/dsf.c
    +++ b/src/dsf.c
    cioè si tratta di cambiare una sola riga, da:
    a:
    e niente altro!
    Ultima modifica di UnixMan : 07-02-2017 a 00:59
    Ciao, Paolo.
Pagina 14 di 115
Ci sono attualmente 9 utenti che stanno visualizzando questa discussione. (0 utenti e 9 ospiti)
