Allora Marco
con aiff mi sembra che non fa resample
Con i wav niente...qualche rumore iniziale e poi nientecodice:Server: Logitech Media Server (7.9.0 - 1443102866) Connection: close Content-Type: audio/x-aiff [21:14:38.262129] sendRESP:202 RESP [21:14:38.376139] _check_header:159 unknown format - can't parse header in strea m, using server parameters [21:14:38.376486] pcm_decode:200 setting track_start [21:14:38.383108] _output_frames:61 start buffer frames: 331776 [21:14:38.383138] _output_frames:146 track start sample rate: 44100 replay_gain: 0 [21:14:38.383147] sendSTAT:171 STAT: STMs [21:14:38.383183] sendSTAT:171 STAT: STMt [21:14:39.384193] sendSTAT:171 STAT: STMt
codice:Server: Logitech Media Server (7.9.0 - 1443102866) Connection: close Content-Type: audio/L16 [21:15:53.336712] sendRESP:202 RESP [21:15:56.406350] process:494 strm [21:15:56.406363] process_strm:256 strm command t [21:15:56.406369] sendSTAT:171 STAT: STMt [21:15:59.429105] _check_header:77 WAVE [21:15:59.429128] _check_header:101 header: fmt len: 40 [21:15:59.429140] _check_header:129 pcm size: 3 rate: 384000 chan: 2 bigendian: 0 [21:15:59.429151] _check_header:101 header: fact len: 4 [21:15:59.429159] _check_header:101 header: data len: -730436756 [21:15:59.429169] _check_header:107 audio size: 3564530540 [21:15:59.429179] pcm_decode:200 setting track_start [21:15:59.432339] _output_frames:61 start buffer frames: 135154 [21:15:59.432357] _output_frames:146 track start sample rate: 384000 replay_gain : 0 [21:15:59.432362] sendSTAT:171 STAT: STMs [21:15:59.432381] sendSTAT:171 STAT: STMt [21:15:59.442364] output_thread:638 open output device: front:CARD=J20,DEV=0 [21:15:59.442612] alsa_open:355 opening device at: 384000 [21:15:59.442852] alsa_open:406 opened device front:CARD=J20,DEV=0 using format: S32_LE sample rate: 384000 mmap: 1 [21:15:59.442869] alsa_open:485 buffer: 40 period: 4 -> buffer size: 15360 perio d size: 3840 [21:16:00.433395] sendSTAT:171 STAT: STMt [21:16:00.433416] sendSTAT:171 STAT: STMo [21:16:00.485009] process:494 strm [21:16:00.485020] process_strm:256 strm command p [21:16:00.485026] sendSTAT:171 STAT: STMp [21:16:00.485035] process_strm:292 pause interval: 0 [21:16:00.610293] process:494 strm [21:16:00.610303] process_strm:256 strm command t [21:16:00.610309] sendSTAT:171 STAT: STMt [21:16:00.910519] process:494 strm [21:16:00.910530] process_strm:256 strm command t [21:16:00.910535] sendSTAT:171 STAT: STMt
Rettifico anche con aiff niente
codice:HTTP/1.1 200 OK Server: Logitech Media Server (7.9.0 - 1443102866) Connection: close Content-Type: audio/L16 [21:21:46.536283] sendRESP:202 RESP [21:21:48.982393] stream_thread:249 end of stream [21:21:48.982428] sendDSCO:190 DSCO: 0 [21:21:48.983536] process:494 strm [21:21:48.983548] process_strm:256 strm command u [21:21:48.983558] process_strm:312 unpause at: 0 now: 6383983 [21:21:48.983568] sendSTAT:171 STAT: STMr [21:21:49.984588] sendSTAT:171 STAT: STMt [21:21:50.985610] sendSTAT:171 STAT: STMt [21:21:51.409919] process:494 strm [21:21:51.409932] process_strm:256 strm comman
Ciao, Marco.
Mazza, cos'hai un 40"?
Comunque qualcuno sta provando con Linux ed anche con Mac, vero?
Ciao, Marco.
Aiff
codice:[15-10-22 21:56:30.9119] Slim::Player::Protocols::File::open (98) Opening file C:\Users\filippo\Desktop\Music\Nuova cartella\01 - One.aiff [15-10-22 21:56:30.9121] Slim::Player::Protocols::File::open (192) Seeking in 54 into C:\Users\filippo\Desktop\Music\Nuova cartella\01 - One.aiff [15-10-22 21:56:30.9122] Slim::Player::Song::open (482) URL is a song (audio): file:///C:/Users/filippo/Desktop/Music/Nuova%20cartella/01%20-%20One.aiff, type=aif [15-10-22 21:56:30.9125] Slim::Player::TranscodingHelper::tokenizeConvertCommand2 (617) Using command for conversion: "C:\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\ffmpeg.exe" -vn -v 0 -i - -f wav - | "C:\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\sox.exe" -q -t wav - -t wav -r 384000 -c 2 -3 -s -L - gain -3 rate -v -M -a -b 90.7 384000 [15-10-22 21:56:30.9126] Slim::Player::Song::open (558) Tokenized command: "C:\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\ffmpeg.exe" -vn -v 0 -i - -f wav - | "C:\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\sox.exe" -q -t wav - -t wav -r 384000 -c 2 -3 -s -L - gain -3 rate -v -M -a -b 90.7 384000 [15-10-22 21:56:30.9148] Slim::Player::Pipeline::new (96) Launching process with command: "C:\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\socketwrapper.exe" -D -i 61800 -o 61799 -c "\"C:\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\ffmpeg.exe\" -vn -v 0 -i - -f wav - | \"C:\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\sox.exe\" -q -t wav - -t wav -r 384000 -c 2 -3 -s -L - gain -3 rate -v -M -a -b 90.7 384000" [15-10-22 21:56:30.9330] Slim::Player::SongStreamController::new (31) live=1 [15-10-22 21:56:30.9334] Slim::Player::StreamingController::_Stream (1277) 50:e5:49:cc:b4:29: stream [15-10-22 21:56:30.9338] Slim::Player::StreamingController::_Stream (1314) Song queue is now 0 [15-10-22 21:56:30.9339] Slim::Player::StreamingController::_setPlayingState (2366) new playing state BUFFERING [15-10-22 21:56:30.9341] Slim::Player::StreamingController::_setStreamingState (2375) new streaming state STREAMING [15-10-22 21:56:30.9342] Slim::Player::StreamingController::_eventAction (303) 50:e5:49:cc:b4:29: NextTrackReady - new state BUFFERING-STREAMING [15-10-22 21:56:30.9344] Slim::Player::StreamingController::_eventAction (303) 50:e5:49:cc:b4:29: Play - new state BUFFERING-STREAMING [15-10-22 21:56:30.9433] Slim::Player::TranscodingHelper::enabledFormat (209) Checking to see if aif-aif-*-* is enabled [15-10-22 21:56:30.9435] Slim::Player::TranscodingHelper::enabledFormat (217) There are 5 disabled formats... [15-10-22 21:56:30.9436] Slim::Player::TranscodingHelper::enabledFormat (223) Testing aif-aif-*-* vs aif-aif-*-* [15-10-22 21:56:30.9438] Slim::Player::TranscodingHelper::enabledFormat (227) ** aif-aif-*-* Disabled ** [15-10-22 21:56:30.9439] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: aif-dsf-squeezelite-50:e5:49:cc:b4:29 [15-10-22 21:56:30.9440] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: aif-dsf-*-50:e5:49:cc:b4:29 [15-10-22 21:56:30.9442] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: aif-dsf-squeezelite-* [15-10-22 21:56:30.9443] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: aif-dsf-*-* [15-10-22 21:56:30.9445] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: aif-dff-squeezelite-50:e5:49:cc:b4:29 [15-10-22 21:56:30.9446] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: aif-dff-*-50:e5:49:cc:b4:29 [15-10-22 21:56:30.9449] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: aif-dff-squeezelite-* [15-10-22 21:56:30.9450] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: aif-dff-*-* --------------------------------------------------------------------------------------------------- [15-10-22 21:56:35.9976] Slim::Player::TranscodingHelper::checkBin (250) enabled [15-10-22 21:56:35.9976] Slim::Player::TranscodingHelper::checkBin (252) Found command: [ffmpeg] -vn -v 0 $START$ $END$ -i $FILE$ -f wav - | [sox] -q -t wav - -t wav -r 384000 -c 2 -3 -s -L - gain -3 rate -v -M -a -b 90.7 384000 [15-10-22 21:56:35.9978] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: aif->pcm via: [ffmpeg] -vn -v 0 $START$ $END$ -i $FILE$ -f wav - | [sox] -q -t wav - -t wav -r 384000 -c 2 -3 -s -L - gain -3 rate -v -M -a -b 90.7 384000 [15-10-22 21:56:36.0027] Slim::Player::StreamingController::_eventAction (271) 50:e5:49:cc:b4:29: StatusHeartbeat in PLAYING-STREAMOUT -> Slim::Player::StreamingController::_CheckSync [15-10-22 21:56:37.0039] Slim::Player::StreamingController::_eventAction (271) 50:e5:49:cc:b4:29: StatusHeartbeat in PLAYING-STREAMOUT -> Slim::Player::StreamingController::_CheckSync [15-10-22 21:56:38.0045] Slim::Player::StreamingController::_eventAction (271) 50:e5:49:cc:b4:29: StatusHeartbeat in PLAYING-STREAMOUT -> Slim::Player::StreamingController::_CheckSync [15-10-22 21:56:39.0012] Slim::Player::StreamingController::_eventAction (271) 50:e5:49:cc:b4:29: StatusHeartbeat in PLAYING-STREAMOUT -> Slim::Player::StreamingController::_CheckSync [15-10-22 21:56:40.0014] Slim::Player::StreamingController::_eventAction (271) 50:e5:49:cc:b4:29: StatusHeartbeat in PLAYING-STREAMOUT -> Slim::Player::StreamingController::_CheckSync [15-10-22 21:56:41.0025] Slim::Player::StreamingController::_eventAction (271) 50:e5:49:cc:b4:29: StatusHeartbeat in PLAYING-STREAMOUT -> Slim::Player::StreamingController::_CheckSync [15-10-22 21:56:42.0034] Slim::Player::StreamingController::_eventAction (271) 50:e5:49:cc:b4:29: StatusHeartbeat in PLAYING-STREAMOUT -> Slim::Player::StreamingController::_CheckSync
Wav
codice:[15-10-22 22:23:56.1538] Slim::Player::Protocols::File::open (98) Opening file C:\Users\filippo\Desktop\Music\Nuova cartella\01 - One.wav [15-10-22 22:23:56.1540] Slim::Player::Protocols::File::open (192) Seeking in 44 into C:\Users\filippo\Desktop\Music\Nuova cartella\01 - One.wav [15-10-22 22:23:56.1542] Slim::Player::Song::open (482) URL is a song (audio): file:///C:/Users/filippo/Desktop/Music/Nuova%20cartella/01%20-%20One.wav, type=wav [15-10-22 22:23:56.1544] Slim::Player::TranscodingHelper::tokenizeConvertCommand2 (617) Using command for conversion: "C:\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\ffmpeg.exe" -vn -v 0 -i - -f wav - | "C:\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\sox.exe" -q -t wav - -t wav -r 384000 -c 2 -3 -s -L - gain -3 rate -v -M -a -b 90.7 384000 [15-10-22 22:23:56.1545] Slim::Player::Song::open (558) Tokenized command: "C:\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\ffmpeg.exe" -vn -v 0 -i - -f wav - | "C:\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\sox.exe" -q -t wav - -t wav -r 384000 -c 2 -3 -s -L - gain -3 rate -v -M -a -b 90.7 384000 [15-10-22 22:23:56.1566] Slim::Player::Pipeline::new (96) Launching process with command: "C:\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\socketwrapper.exe" -D -i 63507 -o 63506 -c "\"C:\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\ffmpeg.exe\" -vn -v 0 -i - -f wav - | \"C:\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\sox.exe\" -q -t wav - -t wav -r 384000 -c 2 -3 -s -L - gain -3 rate -v -M -a -b 90.7 384000" [15-10-22 22:23:56.1726] Slim::Player::SongStreamController::new (31) live=1 [15-10-22 22:23:56.1730] Slim::Player::StreamingController::_Stream (1277) 50:e5:49:cc:b4:29: stream [15-10-22 22:23:56.1734] Slim::Player::StreamingController::_Stream (1314) Song queue is now 0 [15-10-22 22:23:56.1735] Slim::Player::StreamingController::_setPlayingState (2366) new playing state BUFFERING [15-10-22 22:23:56.1736] Slim::Player::StreamingController::_setStreamingState (2375) new streaming state STREAMING [15-10-22 22:23:56.1737] Slim::Player::StreamingController::_eventAction (303) 50:e5:49:cc:b4:29: NextTrackReady - new state BUFFERING-STREAMING [15-10-22 22:23:56.1738] Slim::Player::StreamingController::_eventAction (303) 50:e5:49:cc:b4:29: Play - new state BUFFERING-STREAMING [15-10-22 22:23:56.1860] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-dsf-squeezelite-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1861] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-dsf-*-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1863] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-dsf-squeezelite-* [15-10-22 22:23:56.1864] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-dsf-*-* [15-10-22 22:23:56.1865] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-dff-squeezelite-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1866] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-dff-*-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1868] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-dff-squeezelite-* [15-10-22 22:23:56.1869] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-dff-*-* [15-10-22 22:23:56.1870] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-alc-squeezelite-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1871] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-alc-*-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1872] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-alc-squeezelite-* [15-10-22 22:23:56.1874] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-alc-*-* [15-10-22 22:23:56.1875] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-wma-squeezelite-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1876] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-wma-*-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1877] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-wma-squeezelite-* [15-10-22 22:23:56.1878] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-wma-*-* [15-10-22 22:23:56.1880] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-wmap-squeezelite-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1881] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-wmap-*-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1882] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-wmap-squeezelite-* [15-10-22 22:23:56.1883] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-wmap-*-* [15-10-22 22:23:56.1884] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-wmal-squeezelite-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1886] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-wmal-*-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1887] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-wmal-squeezelite-* [15-10-22 22:23:56.1888] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-wmal-*-* [15-10-22 22:23:56.1889] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-aac-squeezelite-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1890] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-aac-*-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1890] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-aac-squeezelite-* [15-10-22 22:23:56.1891] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-aac-*-* [15-10-22 22:23:56.1892] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-ogg-squeezelite-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1893] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-ogg-*-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1894] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-ogg-squeezelite-* [15-10-22 22:23:56.1896] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-ogg-*-* [15-10-22 22:23:56.1896] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-flc-squeezelite-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1897] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-flc-*-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1898] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-flc-squeezelite-* [15-10-22 22:23:56.1899] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-flc-*-* [15-10-22 22:23:56.1900] Slim::Player::TranscodingHelper::enabledFormat (209) Checking to see if wav-flc-*-* is enabled [15-10-22 22:23:56.1901] Slim::Player::TranscodingHelper::enabledFormat (217) There are 5 disabled formats... [15-10-22 22:23:56.1902] Slim::Player::TranscodingHelper::enabledFormat (223) Testing aif-aif-*-* vs wav-flc-*-* [15-10-22 22:23:56.1903] Slim::Player::TranscodingHelper::enabledFormat (223) Testing aif-flc-*-* vs wav-flc-*-* [15-10-22 22:23:56.1905] Slim::Player::TranscodingHelper::enabledFormat (223) Testing flc-aif-*-* vs wav-flc-*-* [15-10-22 22:23:56.1906] Slim::Player::TranscodingHelper::enabledFormat (223) Testing flc-flc-*-* vs wav-flc-*-* [15-10-22 22:23:56.1906] Slim::Player::TranscodingHelper::enabledFormat (223) Testing wav-flc-*-* vs wav-flc-*-* [15-10-22 22:23:56.1907] Slim::Player::TranscodingHelper::enabledFormat (227) ** wav-flc-*-* Disabled ** [15-10-22 22:23:56.1908] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-aif-squeezelite-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1909] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-aif-*-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1910] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-aif-squeezelite-* [15-10-22 22:23:56.1911] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-aif-*-* [15-10-22 22:23:56.1912] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-pcm-squeezelite-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1913] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-pcm-*-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1914] Slim::Player::TranscodingHelper::enabledFormat (209) Checking to see if wav-pcm-*-50:e5:49:cc:b4:29 is enabled [15-10-22 22:23:56.1915] Slim::Player::TranscodingHelper::enabledFormat (217) There are 5 disabled formats... [15-10-22 22:23:56.1915] Slim::Player::TranscodingHelper::enabledFormat (223) Testing aif-aif-*-* vs wav-pcm-*-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1916] Slim::Player::TranscodingHelper::enabledFormat (223) Testing aif-flc-*-* vs wav-pcm-*-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1917] Slim::Player::TranscodingHelper::enabledFormat (223) Testing flc-aif-*-* vs wav-pcm-*-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1918] Slim::Player::TranscodingHelper::enabledFormat (223) Testing flc-flc-*-* vs wav-pcm-*-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1919] Slim::Player::TranscodingHelper::enabledFormat (223) Testing wav-flc-*-* vs wav-pcm-*-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1920] Slim::Player::TranscodingHelper::checkBin (250) enabled [15-10-22 22:23:56.1922] Slim::Player::TranscodingHelper::checkBin (252) Found command: [ffmpeg] -vn -v 0 $START$ $END$ -i $FILE$ -f wav - | [sox] -q -t wav - -t wav -r 384000 -c 2 -3 -s -L - gain -3 rate -v -M -a -b 90.7 384000 [15-10-22 22:23:56.1923] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: wav->pcm via: [ffmpeg] -vn -v 0 $START$ $END$ -i $FILE$ -f wav - | [sox] -q -t wav - -t wav -r 384000 -c 2 -3 -s -L - gain -3 rate -v -M -a -b 90.7 384000 [15-10-22 22:23:56.1927] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-dsf-squeezelite-50:e5:49:cc:b4:29 [15-10-22 22:23:56.1928] Slim::Player::TranscodingHelper::checkBin (242) Checking formats for: wav-dsf-*-50:e5:49:cc:b4:29 ----------------------------------------------------------------------------------------------------------------------------------------------------- [15-10-22 22:24:13.8795] Slim::Player::TranscodingHelper::checkBin (252) Found command: [ffmpeg] -vn -v 0 $START$ $END$ -i $FILE$ -f wav - | [sox] -q -t wav - -t wav -r 384000 -c 2 -3 -s -L - gain -3 rate -v -M -a -b 90.7 384000 [15-10-22 22:24:13.8797] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: wav->pcm via: [ffmpeg] -vn -v 0 $START$ $END$ -i $FILE$ -f wav - | [sox] -q -t wav - -t wav -r 384000 -c 2 -3 -s -L - gain -3 rate -v -M -a -b 90.7 384000 [15-10-22 22:24:14.0010] Slim::Player::StreamingController::_eventAction (271) 50:e5:49:cc:b4:29: StatusHeartbeat in STOPPED-IDLE -> Slim::Player::StreamingController::_NoOp [15-10-22 22:24:19.0014] Slim::Player::StreamingController::_eventAction (271) 50:e5:49:cc:b4:29: StatusHeartbeat in STOPPED-IDLE -> Slim::Player::StreamingController::_NoOp [15-10-22 22:24:24.0013] Slim::Player::StreamingController::_eventAction (271) 50:e5:49:cc:b4:29: StatusHeartbeat in STOPPED-IDLE -> Slim::Player::StreamingController::_NoOp [15-10-22 22:24:29.0016] Slim::Player::StreamingController::_eventAction (271) 50:e5:49:cc:b4:29: StatusHeartbeat in STOPPED-IDLE -> Slim::Player::StreamingController::_NoOp [15-10-22 22:24:34.0014] Slim::Player::StreamingController::_eventAction (271) 50:e5:49:cc:b4:29: StatusHeartbeat in STOPPED-IDLE -> Slim::Player::StreamingController::_NoOp
Temo che il problema sia che SOX non è silenzioso e questo manda in crisi il modo che LMS di gestire il processo. Almeno con il WAV hai un clipping (che dovresti comunque risolvere, quindi ti consiglio di aumentare i db di calo del guadagno (standard sono 3).
A me funziona, non ho provato AIF, proverò e ti so dire.
Ciao, Marco.
